Vic-1541 Floppy Drive Please help
fsporsche
Post by fsporsche »
Hello,
Hope everyone is fine...
I just purchased from ebay a vic-1541 drive for my vic-20. I got it and plugged it in, turned it on and the green light is on, but the red light keeps flashing and when i put a floppy disk and try the load"$",8 it just keeps loading and it never see's anything on the disk...i have tried several floppys also....The drive when i turn it on it just keeps flashing the red light 3 times and off and on again....
Is there anyway i can stop the red light from flashing?
Does the flashing red light indicate its a bad floppy drive?
Fred
saehn
Post by saehn »
Maybe this?
UC8 74LS42 LOGIC
When drive powered up, spindle motor runs continuously. Red LED may stay on, or flash three times and go out.
Got that info from:
http://personalpages.tds.net/~rcarlsen/cbm/1541chip.txt
Try this too:
http://personalpages.tds.net/~rcarlsen/cbm/fix1541.txt
If you're not technically inclined, it might just be best to grab another one (sold as tested, preferably) and try again...
English Invader
Post by English Invader »
The light should turn green when you switch on the VIC. If the light remains red, it means the drive is not picking up signals from the computer.
