The Great Program Collage
0 dim a(32), b(12), c, d, a$: s=36878: poke s,15: x=7680: q=8: rem denial collage 2009
5 data169,127,141,34,145,173,32,145,10,173,17,145,73,255,41,60,176,2,105,2,74,133,254,96
10 poke36879,8:print"{clr home}":forc=200to250:poke36875,c:poke36875,400-c: next:poke36875,0
15 fort=1to1000:printmid$("{blk,wht,red,cyn,pur,grn,blu,yel}",int(rnd(1)*8)+1,1)"{shift-u,shift-q,shift-i,shift-j,shift-q,shift-k}";:next
20 for t=0to23: read v: poke7168+t,v: next: sys 7168: gosub 40: if e=3 then10
22 d=c+sgn(eand1)-sgn(eand2)*22+sgn(eand4)*22-sgn(eand8):if d>=0 and d<506 then c=d
27 pokes-2,200:pokes-2,0:ifpeek(x+c)<>81thenpokex+c,36:onint(rnd(1)*3)gosub100,200
40 ifq=8thenpoke37154,255:e=peek(254):q=0:return
200 d=c-int(c/22)*22:fori=0to22:pokex+d+i*22,160:next
30 print"{home}{red}waffles:{white}"w;tab(10)"{red}cowboys:{white}"cb: r=(r+1)and7
[insert your line here]
205 a(d)=1:if a(d+1)=1 or a(d-1)=1 then 225
204 ifd=0then206
Ok, a brief summary what seems to be happening:
First a sound effect, then 1000 birds are drawn on the screen. The nifty little machine code routine reads the joystick and stores a value in address 254:
0 = no move
1 = right
2 = up
4 = down
8 = left
16 = fire
I suppose one just as well could've read the joystick from Basic but since Jeff-20 set up a promise for a ML routine it seemed somehow appropriate.
Since Q at the moment is 8 when we get to line 40, the joystick will be read, Q reset and back to the main program. If the joystick at that moment is pulled up-right (NE position), the program will more or less restart. The 1000 birds get redrawn, with the exception that on line 40 the Q=8 check no longer is true so only God knows what will happen then.
If the joystick was moved in another direction or not at all, the variable C which is a left-over from the sound effect, is used as player index on screen. If the player has moved to a square that is not populated with a ball (bird head), a dollar sign is placed on screen to indicate the player's position. Then randomly it will jump to line 100, 200 or not at all.
The routine at 200 paints a line across the screen at the column where the player is. Unless the player is in the leftmost column, a flag is set in the array A().
Of course a lot of this may change in the next few lines, depending on who adds what and where. How all of this is supposed to wrap up and work is a different question.
Good luck with your additions!
0 = no move
1 = right
2 = up
4 = down
8 = left
16 = fire
Did this program stop growing?
Actually I have a different idea. Instead of making a mish-mash of spaghetti code, if Jeff allows we could group together to create Game Theory III, or if it is IV. A bunch of small games in the same style as the first two but where input from more people may result in even greater variety of minigames.
- Pedro Lambrini
That is genius. You could call the collection A Theory In Denial!carlsson wrote:Did this program stop growing?
Yes! That may be what I had hoped would happen naturally. I like your idea! Figuring out the shared routines first would be best. Then we have to keep an active list of variables... etc. etc.carlsson wrote:Did this program stop growing?
