The Great Program Collage
Feel free to add a single line to the program collage. Who knows maybe it'll turn out to be a game or something interesting. I have no direction or intentions.
Just try not to crash it. You can add one line only. You may add as many as you like to the whole program, but only one at a time (you can't add two consecutive lines). You cannot alter previous lines unless there's an apparent error. Repost the entire code with your additional line.
Note: Assume this will run on an unexpanded system
0 DIM A(32), B(12), C, D, A$: S=36878: POKE S,15: X=7680: Q=8: REM DENIAL COLLAGE 2009
[insert your line here]
Boray
Musical Smurf
Post by Boray »
:D Cool idea!
0 dim a(32), b(12), c, d, a$: s=36878: poke s,15: x=7680: q=8: rem denial collage 2009
10 poke36879,8:print"{clr home}":forc=200to250:poke36875,c:poke36875,400-c: next:poke36875,0
Adding a colourful swarm of birds ...
15 fort=1to1000:printmid$("{blk,wht,red,cyn,pur,grn,blu,yel}",int(rnd(1)*8)+1,1)"{shift-u,shift-q,shift-i,shift-j,shift-q,shift-k}";:next
You guys are far too nice. :D
20 for t=0to23: read v: poke7168+t,v: next: sys 7168: gosub 40: if e=3 then10
hehehe, work with that! :lol:
Also, your line doesn't need to come at the end; you can also insert a line where space is available.
5 data169,127,141,34,145,173,32,145,10,173,17,145,73,255,41,60,176,2,105,2,74,133,254,96
You may need to use the abbreviation D + SHIFT-A to enter that line, but it will fit!
Hint for the next contributor: PEEK(254)
40 ifq=8thenpoke37154,255:e=peek(254):q=0:return
22 d=c+sgn(eand1)-sgn(eand2)*22+sgn(eand4)*22-sgn(eand8):if d>=0 and d<506 then c=d
A discipline question: should the newest line always go at the end, and the next editor gets to sort it into the listing? I think it adds clarity what was added, in particular as I twice injected a line in the middle of others.
27 pokes-2,200:pokes-2,0:ifpeek(x+c)<>81thenpokex+c,36:onint(rnd(1)*3)gosub100,200
carlsson wrote:A discipline question: should the newest line always go at the end, and the next editor gets to sort it into the listing? I think it adds clarity what was added, in particular as I twice injected a line in the middle of others.
Yep. I can't wait to run this thing! I barely know what's going on now. But I'm just going to keep adding stuff. I encourage all to do the same regardless of your programming confidence. :lol:
Line 15 keeps me from just pasting it into VICE. Also, be sure not to go over the 88 character limit. :)
200 d=c-int(c/22)*22:fori=0to22:pokex+d+i*22,160:next
If this doesn't turn out as spaghetti code, nothing will! :lol:
Boray
Musical Smurf
Post by Boray »
What if two people started writing a new line at the same time? How about this simple ticket/queue system: If you want to add a line to the program, post a reply with just the words "MY TURN". After that, instead of making a new post, just edit that "MY TURN" post into a new post with your new program change. And if you see that someone has posted "MY TURN" before you, then you just have to wait until he is finished. You have to check this before you press the Edit button for your "MY TURN" post.
Boray
Musical Smurf
Post by Boray »
And if you see a "MY TURN" post and want to be the next in line, you can of course just post a "MY TURN" and wait...
Schema
factor
Post by Schema »
Boray wrote:What if two people started writing a new line at the same time?
You guys should try this using EtherPad or similar: http://etherpad.com/
As long as the line numbers don't conflict, there shouldn't be a problem. Otherwise, we just change the line number. :lol:
We don't really have a clear goal. I now think we should've kept everything nice and linear. I have little idea what's going on in the code already! haha
Do you want a summary, approximately what is going on? At least it seems Mike and me are quite on track, although I suppose neither of us have a clue how to bring it all home.
