I just ordered one on ebay. Got it in the mail connected it to my vic-20 and powered it on. I Put a floppy disk in and when i did the (load"*",8 ,1) command nothing happens....The drive does not show the light that it is reading the floppy....it just stays in the searching command with nothing accessing from the vic-1541 drive.....Is there anything i can do? maybe the drive number has been changed? please help..... Crying or Very sad
[mod: crosspost in 'Programming' section removed]
Commodore vic-1541 Help
Re: Commodore vic-1541 Help
Is there anything on the disk? Are you able to read a directory? Is the disk formatted?fsporsche wrote:I Put a floppy disk in and when i did the (load"*",8 ,1) command nothing happens....
Did you attempt to ascertain this by addressing a different device number?maybe the drive number has been changed?
Try reading http://personalpages.tds.net/~rcarlsen/cbm/fix1541.txt and http://personalpages.tds.net/~rcarlsen/cbm/1541chip.txtfsporsche wrote:Please help me narrow it down
I second this with the addition that it is more likely that you have to replace the 7406 and/or the 74LS14 in the 1541. You find them top/left on the board, near the IEC-connectors.shem wrote:hi there it sounds like it could be either the right 6522 or the 74ls06
on the vic 20
either that or you have a problem with the logic pcb in the 1541
also check your cable try another one if you have one
___
/ __|__
\ \__|_\
\___| URL: www.baltissen.org
