20 Lines: Tetris
ravenxau
20 Lines: Tetris
Post by ravenxau »
I didn't write it - but it does fit the critera
1 REM PETRIS (C)2002 CURTIS F KAYLOR
2 T$="{RIGHT}{RIGHT}{RIGHT}{RIGHT}{RIGHT}{RIGHT}{RIGHT} {RIGHT}{RIGHT} {RIGHT}{RIGHT}{RIGHT}  {RIGHT} {RIGHT}{RIGHT}{RIGHT} {RIGHT} {RIGHT}  {RIGHT}{RIGHT}    {RIGHT}{RIGHT}{RIGHT} {RIGHT}{RIGHT}  {RIGHT} {RIGHT} {RIGHT}    {RIGHT}{RIGHT}  {RIGHT}    {RIGHT}    "
3 DIMT$(15):FORI=0TO15:T$(I)=MID$(T$,4*I+1,4):NEXT:DIMB%(6,3,3):DIMP(23)
4 B$="DDDD@O@@DDDD@O@@@FDD@GA@@AAC@DG@@FBB@AG@@DDF@GD@@BFB@BG@@BCB@GB@@ACB@FC@"
5 B$=B$+"@ACB@FC@@DFB@CF@@DFB@CF@@FF@@FF@@FF@@FF@":FORI=0TO6:FORJ=0TO3:FORK=0TO3
6 Z=Z+1:B%(I,J,K)=ASC(MID$(B$,Z))AND15:NEXT:NEXT:NEXT:FORI=0TO19:P(I)=4097:NEXT:P(I)=8191
7 PRINT"{CLR}":FORI=0TO20:P=P(I):PRINT"{RVS ON}"T$(P/4096)T$(P/256AND15)T$(P/16AND15)T$(PAND15):NEXT
8 PRINT "{UP}{RIGHT}{RIGHT}{RIGHT}{RIGHT}{RVS ON}PETRIS";S
9 X=5:Y=0:B=7*RND(0):C=0:D=2:PRINT"{HOME}{RIGHT}{RIGHT}{RIGHT}{RIGHT}{RIGHT}{RIGHT}{RIGHT}{DOWN}";:R=1
10 IFRTHEND$="":FORI=0TO3:D$=D$+T$(B%(B,C,I))+"{DOWN}{LEFT}{LEFT}{LEFT}{LEFT}":NEXT:D$=D$+"{UP}{UP}{UP}{UP}"
11 PRINT CHR$(93*ABS(M)+64*M)"{RVS ON}";D$;:IF M+R THEN M=0:R=0:GOTO14
12 GET K$:M=(K$="{RIGHT}")-(K$="{DOWN}"):R=(K$=" "):IFMTHENX=X+M:GOSUB16:IFZTHENX=X-M:M=0
13 IFRTHENC=C-RAND3:GOSUB16:IFZTHENC=C+RAND3:R=0
14 IF M+R=0 THEN Y=Y+1:GOSUB16:IF Z THEN Y=Y-1:ONSGN(Y)GOTO17:END
15 PRINT"{RVS OFF}"D$;CHR$(-17*(M+R=0));:GOTO10
16 Z=0:T=2^X:FORI=0TO3:Z=Z+(P(Y+I)ANDB%(B,C,I)*T):NEXT:RETURN
17 A=0:FORI=0TO3:P(Y+I)=P(Y+I)ORB%(B,C,I)*T:IFP(Y+I)=8191ANDY+I<20THENGOSUB19
18 NEXT:ONDGOTO7,9
19 FORZ=Y+ITO1STEP-1:P(Z)=P(Z-1):NEXT:P(0)=4097:D=1:A=A+10:S=S+A:RETURN
Android Tablet running Frodo 64 emulator running VIC 20 emulator....
Dude, can you post a PRG or something? Even after converting this to lowercase, I get SYNTAX errors pasting it into VICE... sigh. Some of the lines may have been crunched to fit.
ravenxau
Post by ravenxau »
Jeff-20 wrote:Dude, can you post a PRG or something? Even after converting this to lowercase, I get SYNTAX errors pasting it into VICE... sigh. Some of the lines may have been crunched to fit.
try here :)
http://www.cling.gu.se/~cl3polof/miniga ... petris.zip
when loading in vice use load"petris.prg",8
do NOT include ,1 at the end
Wow.... I can't wrap my head around the code. This game is giving me an inferior complex! :lol:
ravenxau
Post by ravenxau »
Jeff-20 wrote:Wow.... I can't wrap my head around the code. This game is giving me an inferior complex! :lol:
Yes to that! - I consider myself a reasonable coder (C++, VB.NET, ASP PHP, SQL and some simple 6502 Assembly), and i haven't been able to unravel the secrets of this gem :(
DanSolo
Post by DanSolo »
Holy JC, lines 6 and 7 are the most divinely cryptic lines of code I've ever seen. Do they store the shapes of the various blocks in little 4x4 arrays?
gklinger
Vic 20 Elite
Post by gklinger »
DanSolo wrote:Do they store the shapes of the various blocks in little 4x4 arrays?
Ask Curtis directly. :)
It might be useful to point out Petris was part of the 2002 MiniGame Compo. As far as I know it is written to be runnable on any Commodore computer with Microsoft Basic, i.e. from PET 2001 to C128, perhaps even C65.
ravenxau
Post by ravenxau »
carlsson wrote:It might be useful to point out Petris was part of the 2002 MiniGame Compo. As far as I know it is written to be runnable on any Commodore computer with Microsoft Basic, i.e. from PET 2001 to C128, perhaps even C65.
you are correct - I myself have run it on three different commodore platforms.
