40 column word processor?
I did a quick search on Google and on here, and I see no mention anywhere of a 40 column word processor for the VIC-20. I know there were several 80 column programs for the C64 - I'm just wondering if there is one out there? If not, maybe I have to build my own - add that to my list of stuff that I'll start and never finish! LOL!
Thanks!
Rick Towns
Barrie, Ontario, CANADA
Thanks!
Rick Towns
Re: 40 column word processor?
I'm not sure about 40 columns but there is an 80 column word processor for the VIC-20 that requires a Data-20 or Protecto 80 (different names for identical 40/80 column cartridges). I don't know of any that run without the dedicated hardware.
You could always write a simple word processor in BASIC that would work with one of the 40 column programs (FAT 40, Super Screen, Screen-40, VIC 40 etc.) Come to think of it, KP Word Pro is BASIC so it might work. I'll have to try that out.
I had a look at FAT-40, but I don't really like the font design too much. I much prefer Compute's Screen-40 program. That's what I run all the time. I elected to build my own simple word processor instead of trying to get someone elses to work. Well, really my program is more like Windows Notepad than an actual word processor. I just need something I can edit .cfm files in, so I can program for work on my VIC! LOL!
It's about 30% done - hoping to have it finished for this week sometime. Hey... another project I might actually finish! What is going on here? LOL!
Here's an ASCII font I designed for another project I'm currently involved with. The upper case letters are only 6 pixels high, but there are still 8 pixels total, which IMO gives a more eye-pleasing line spacing:BBQedIguana wrote:I had a look at FAT-40, but I don't really like the font design too much. I much prefer Compute's Screen-40 program.
In the Screen-40 version I had found on Zimmers, I couldn't enable lower case. How did you do it?
A 40-column text editor might have been a nice follow-up project for me after releasing the 1.0 version of MINIPAINT. So I'm glad another fellow here takes up the task.Hey... another project I might actually finish! What is going on here?
That is a cool font! It might be nice to have some vertical spacing between the lines. I believe Screen-40 allows me to set the character set to whatever I want (since it's already in RAM).Mike wrote:In the Screen-40 version I had found on Zimmers, I couldn't enable lower case. How did you do it?
To switch between upper and lower case, print a CHR$(6) - it is annoying that it's a toggle, instead of two different calls for upper and lower. I haven't figured out a way yet to auto-detect which case the VIC is in for my programs.
This is the "play" control code used in Super Expander ..., you can also produce it by pressing Ctrl + Left arrow key, and it will appear as inverse F within quotes.BBQedIguana wrote:To switch between upper and lower case, print a CHR$(6)[...]
One quick search within Screen-40 led me to this code snippet:I haven't figured out a way yet to auto-detect which case the VIC is in for my programs.
; Entered with A=6, when CHR$(6) should be output.
.C:2428 A2 18 LDX #$18
.C:242a DD 38 26 CMP $2638,X
.C:242d F0 19 BEQ $2448 ; A=6 => X=14, and jumps.
.C:242f CA DEX
.C:2430 10 F8 BPL $242A
.C:2448 E0 04 CPX #$04
.C:244a 90 0C BCC $2458
.C:244c A5 D4 LDA $D4
.C:244e F0 08 BEQ $2458
.C:2450 A5 D7 LDA $D7
.C:2452 10 B6 BPL $240A
.C:2454 09 40 ORA #$40
.C:2456 D0 AE BNE $2406
.C:2458 20 5E 24 JSR $245E
.C:245b 4C 1F 24 JMP $241F
.C:245e BD 68 26 LDA $2668,X
.C:2461 48 PHA
.C:2462 BD 50 26 LDA $2650,X
.C:2465 48 PHA ; for X=14 these two PHA's push $2480 - 1 on the stack.
.C:2466 60 RTS
.C:2480 AD 87 02 LDA $0287
.C:2483 49 04 EOR #$04
.C:2485 2C A9 00 BIT $00A9
.C:2488 2C A9 04 BIT $04A9
.C:248b 8D 87 02 STA $0287
.C:248e 60 RTS
If you're interested in using this font, PM me your e-mail. I'll then send you the original definition, and save you the hassle of extracting that from the *.png file.That is a cool font! It might be nice to have some vertical spacing between the lines. [...]
Hey Rick, are you still there? One week passed since then!BBQedIguana wrote:It's about 30% done - hoping to have it finished for this week sometime. Hey... another project I might actually finish! What is going on here? LOL!
Hope to see your 40 column wordprocessor / notepad finished...
In the meantime, see what I came across - funny memories about what word processing was in the early 1980s.
http://home.att.net/~arendtj/word_proc_h_01.html
Maybe the Degrees of Separation are less than six...
Did this ever get released publically (the 40 column notepad)? I would love to see Speedscript running in 40 columns on the VIC!
