help with cassette recorder
aaronfire
Post by aaronfire »
Hi everyone:
im having trouble with my cm2 cassette recorder when i run the following test program i get an "out of memory" error...
10 print" this is a test"
save test
new
load test
i have a red button on the side of my vic, and i got it used, mabie it was modded, any suggestions?????
please let me know....
Regards: Aaron...
English Invader
Post by English Invader »
I'm new to the VIC myself, but I fear your problem is with the VIC itself rather than the datasette. For the most part, the datasette just needs a bit of a head-clean or some realignment. Do you get the full 3583 Bytes on the VIC screen?
Your C2N may be terribly poor or there is some fault in the VIC. Usually OUT OF MEMORY happens immediately after FOUND if the azimuth angle on the R/W head is misaligned. But since you recorded the program using the same recorder as you read it back with, I don't think it should happen.
nbla000
Salmon Run
Post by nbla000 »
carlsson wrote:But since you recorded the program using the same recorder as you read it back with, I don't think it should happen.
Yes, this is really strange, try to repeat your tests with another vic or with a C64, even if head is misaligned, you should read what you have saved with the same datassette unless head is really dirty, try to clean it with alcohol and cotton.
