Denial Forum Index Denial
The Commodore Vic 20 Forum
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
C64 help?
Goto page 1, 2  Next
Post new topic   Reply to topic    Denial Forum Index -> Other Systems
View previous topic :: View next topic
Author Message
rhurst
Omega Star Commander
PostPosted: Mon Apr 27, 2009 3:26 pm    Post subject: C64 help? Reply with quote
I got these two C64, both not working:
1) powers-up, the screen does go black (TV and video monitor), nothing more.
2) powers-up, screen initializes 38911 bytes free, no blinking cursor. An Omega Race cartridge starts, but will randomly start (as if FIRE was pressed) and ship will thrust on its own. I can press RESTORE to reset the game, but I cannot invoke any options using the F-keys.
So I got it in my head that I might be able to "cannibalize" one for parts useful for the other... but given those symptoms, where should I focus on?
_________________
Any technology distinguishable from magic is insufficiently advanced. See also magic.
Back to top
View user's profile Send private message Visit poster's website
saehn
PostPosted: Mon Apr 27, 2009 4:58 pm    Post subject: Reply with quote
Check these, great documents:
http://personalpages.tds.net/~rcarlsen/cbm.html
_________________
saehn/Style
Back to top
View user's profile Send private message MSN Messenger
rhurst
PostPosted: Mon Apr 27, 2009 5:20 pm    Post subject: Reply with quote
Excellent, thanks... I'll post if I am successful. This looks interesting to start with:
U1 906108-02 (6526) CIA
Startup screen normal, but no cursor. No keyboard or control port
access. Partial failure: some keys or joystick positions don't work, one
character appears ahead of startup cursor, screen fills at startup as if
keys are being held down. Cartridge works.
_________________
Back to top
shem
PostPosted: Mon Apr 27, 2009 5:31 pm    Post subject: Reply with quote
is it a breadbin or a c64c
things to check 6526 ram and if it is a bredbin check U17 Pla probably the most common fault in the old c64
_________________
I'll take my cart to go thank you Wink
Back to top
View user's profile Send private message Send e-mail
6502dude
megacart
PostPosted: Mon Apr 27, 2009 5:40 pm    Post subject: Reply with quote
If both 6526 chips are in sockets, you can try swapping them to see if trouble moves to disk I/O and keyboard starts working ok.
_________________
Back to top
rhurst
PostPosted: Wed Apr 29, 2009 6:36 pm    Post subject: Reply with quote
Unfortunately, they are both soldered ... where's a good outlet for sockets? I read it's a good idea to put sockets in if you are successful at de-soldering the chip in place.
_________________
Back to top
Bacon
for breakfast
PostPosted: Wed Apr 29, 2009 11:32 pm    Post subject: Reply with quote
Yes, I wouldn't dream of soldering a new chip in place after desoldering the old one. Sorry, can't give any advice on where to buy sockets.
_________________
Bacon
Back to top
PostPosted: Thu Apr 30, 2009 1:38 am    Post subject: Reply with quote
The 6526 chips are 40 pin, right? Well, you can buy from whichever electronics reseller you like. In the US, Jameco and Digi-Key might be the two biggest. A little pricy but with a big inventory. If you want to go cheap, try Futurlec which ships their stuff from Thailand. I recently placed an order from them and didn't have reason to complain.
Of course it depends how many sockets you need. One, two, ten, fifty.. any other parts? Perhaps you even have a local dealer stocking from one of the resellers, at a slightly higher margin but without a minimum order value.
_________________
Back to top
View user's profile Send private message Send e-mail Visit poster's website
saehn
PostPosted: Thu Apr 30, 2009 12:14 pm    Post subject: Reply with quote
Wait, how comfortable do you feel with desoldering a chip while maintaining its functionality? It's not that easy, IMO. I'm pretty new to soldering, but I've done some reasonably involved jobs... and I still wouldn't want to undertake that task lightly. Maybe you should just consider sending it off to someone for repair?
_________________
saehn/Style
Back to top
Bacon
for breakfast
PostPosted: Fri May 01, 2009 1:15 am    Post subject: Reply with quote
You may already know this, but here goes since I've done this a few times: The 6526 is very sensitive to static discharges so you'd have to make sure both you, the C64, and your soldering iron are properly grounded. For the actual desoldering I usually place the board in a vertical position which allows me to heat the chip pins with the iron on the component side while simultaneously working the desoldering pump from the other side. All pins on the 6526 except for the GND pin are easy to desolder; just a quick heating of the pin, and the solder can be sucked out. The GND pin is another story -- it takes a lot of heat to get it unsoldered. Presumably the ground plane inside the chip and on the PCB absorbs much of the heat.
_________________
Bacon
Back to top
rhurst
PostPosted: Fri May 01, 2009 4:25 am    Post subject: Reply with quote
Thanks for all the good input -- I have a local friend I could tap for the actual operation, as he used to be a Commodore reseller/technician from the 80's and 90's. But I do not want to use up any 'favors', heh.
Finding parts and taking the job on myself isn't enough to inspire me, when I consider the low success probability and the hit on my ego if I were to fail. Razz
So I found this repair shop that will replace the chip, with a socket, so it's worth the small investment to keep this machine working. Thanks again for the feedback!
_________________
Back to top
saehn
PostPosted: Fri May 01, 2009 9:55 am    Post subject: Reply with quote
Thanks for the advice, bacon! I'll keep those tips in mind the next time I need to de-solder an IC.
_________________
saehn/Style
Back to top
rhurst
PostPosted: Wed Jun 17, 2009 5:36 pm    Post subject: Reply with quote
In case you would like to know, here is the final disposition of that C64 unit. I hope you enjoy this as much as I did!! Razz
_________________
Back to top
channelmaniac
PostPosted: Thu Jun 18, 2009 8:11 am    Post subject: Reply with quote
EEEEK!
What a scumbag.
$50 to repair a C64? It does NOT take very long to fix one! It's generally quick enough that I do it for $30 flat rate as long as it's not stuffed with bad chips by an unscrupulous customer.
I have had that happen before!!!!
(Have you thought about outing them on the forum?)
_________________
Call me a cheap bastard... I learned to fix things to save money... even surface mount soldering...
Visit my website: http://www.arcadecomponents.com
Back to top
PostPosted: Thu Jun 18, 2009 8:31 am    Post subject: Reply with quote
I would have bought a known working C64 from a trusted seller, then kept the broken one for parts. Perhaps sold or donated it to someone who knows how to repair them. It kind of reminds me about an episode many years ago when I sent a C64 for repair and got a different chip replaced than what the invoice said they had swapped! Eventually it turned out not to be a fault in the computer, rather failing power supply.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    Denial Forum Index -> Other Systems All times are GMT - 6 Hours
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
