VICMON save command?
BBQedIguana
Post by BBQedIguana »
Here's one I can't seem to remember from nearly 30 years ago. I'm using VICMON for building the ML portions of my BBS program, and it's working fine - except when i try to save! I am typing in:
S "MLTERM",08,6400,64C1
to save my block of memory starting at $6400 and going to $64C0 (and adding 1 extra byte) to my disk drive (device 8 ) but when I do that, VICMON puts a question mark on the 0 in 08 and just gives me another prompt.
I double checked the user manual, and I'm using the right syntax (ie: you don't put $ before the address values, and you put a 0 in front of your single digit device number, double quotes around the file name, S instead of SAVE, etc).
Anyone got any idea what I'm doing wrong? VICMON is supposed to be able to save from memory locations below $7FFF, so $6400 should be fine?
Thanks!
Rick Towns
Barrie, Ontario, CANADA
BBQedIguana
Ah HA! I think I found the problem - I took the cartridge out, blew on it, and put it back in and the save command works fine now. Go figure! :)
Boray
Musical Smurf
Post by Boray »
Schema
factor
Post by Schema »
BBQedIguana wrote:Ah HA! I think I found the problem - I took the cartridge out, blew on it, and put it back in and the save command works fine now. Go figure! :)
http://xkcd.com/218/
:lol:
BBQedIguana
ROTFLMBFHAO! NICE!
6502dude
megacart
Post by 6502dude »
I thought this one was funny
http://xkcd.com/224/
Bacon
for breakfast
Post by Bacon »
xkcd is great. The only thing missing is any VIC-20 references :wink:
Bacon
