***NEW DEMO***
Legacy
***NEW DEMO***
Post by Legacy »
Here it is, the long awaited First Edition from Glaswegian Demo group 'Haxxorz' : FLAPPER author:Legacy
This is to be run on Unexpanded VICE Emulator
flapper.vsf
Legacy
Post by Legacy »
How do I make this into .prg, do I need todo that on a real VIC20
Richard James
Post by Richard James »
If you run VICE from the command line you can access the system monitor and save the BASIC code to disk as a .prg file.
HOWTO get BASIC programs out of VICE
Type in your program or load it.
In the VICE menu select the monitor
type
m 2b 2e
This will print out the start and end address of the BASIC program
remember the VIC stores 16bit addresses as low byte high byte
e.g.
>C:002b 01 10 03 10
start is the first two numbers 01 10 which is 1001
end is the second two numbers 03 10 which is 1003
type
save "test.prg" 0 1001 1003
or whatever numbers are the start and end of BASIC for your program
Note this method will only work for a BASIC program. If you want Machine Code saved you need to work out it's end and start manually. Also I have not tested this method on Microsoft Windows only in Linux.
In case you have trouble I have already converted it to a prg file here.
http://richardjames13.110mb.com/vic20/flapper.zip
Legacy
Post by Legacy »
Thanks!
A tip: clear screen memory instead of colour memory when you are animating things. It will make the traces not visible when you change background colour. Well, perhaps it was an intended effect, I can't determine.
Legacy
Post by Legacy »
This BASIC code is screaming fast, watch out or you won't know what hit you! Demo #2 Legacy
Unexpanded 3583 Bytes Free
legacy.prg
The only way to program better is to find a better programmer. - Legacy 2009
CurtisP
Post by CurtisP »
Legacy wrote:This BASIC code is screaming fast, watch out or you won't know what hit you! Demo #2 Legacy
legacy.prg
Nice use of the VIC registers.
Richard James
Very good. I look forward to seeing more of your work.
