uIEC/SD now available (fwd)
RobertBe
Vic 20 Elite
Post by RobertBe »
---------------Forwarded Message--------------
Date: Feb 3, 11:28 pm
I held off on announcing uIEC/SD availability until I had some stock (impatient folks, you know who you are :-), but I do now have some stock (90 units).
Since uIEC shares the same firmware (kudos to Ingo Korb, who does not get enough recognition for this fine piece of code) as the recently announced SD2IEC, I'll spare everyone rehashing the similarities and just note the differences:
* uIEC/SD is currently the smallest known CBM drive (1.5" x 1.5" by 0.3"). Perfect for embedding in your favorite machine, drive, or calculator (shout out to Tone007, who stuffed one in a CBM pocket calculator)
* uIEC/SD shares the same 128kB Atmel AVR 8-bit microcontroller as the rest of the uIEC line. With 51kB used for firmware, there's plenty of room left for the future.
* uIEC/SD comes complete for use with IEC connector and power supply cassette port connector. VIC/64/C128 users can simply plug the wires in and use. (SX64/+4/C116/C16 users need to source 5V elsewhere, let me know before purchasing if you'd like an alternate connector)
* Although not yet defined for use, uIEC/SD offers an additional switch line and programmatic LED for future use.
* uIEC/SD not only supports SD and SDHC cards, but either SD or SDHC cards can also be used for updating the firmware (new feature, older firmware update software only supports SD cards)
Pictures available at: http://www.jbrain.com/vicug/gallery/uIEC/IMG_6514
As with uIEC/CF, units are $50.00/unit, with shipping (for up to 3 units) as follows:
$5.00/US
$10.00/Canada
$15.00/Intl
Email brain@jbrain.com for ordering information, or simply Paypal the address for immediate purchase.
I'd like to thank all those who have purchased uIEC units. I hope everyone finds them useful.
Jim
I want! Can anyone throw together a quick installation FAQ? I suck with hardware.
gklinger
Vic 20 Elite
Post by gklinger »
You'll think I'm kidding but believe me when I say that it's as simple as hooking up a disk drive. Connect the power, connect the IEC (serial) cable and plug in a memory card instead of a disk and you're cooking with gas.
Pedro Lambrini
Post by Pedro Lambrini »
Mine was shipped this very morning. Cannot wait! Between this and my forth-coming Mega-Cart I am truly sorted in the world of VIC. :)
brain
Post by brain »
Jeff-20 wrote:I want! Can anyone throw together a quick installation FAQ? I suck with hardware.
Can you clarify "installation". uIEC comes ready to use, but if you want to mod it into a VIC, I'm not sure that's a FAQ item...
Complete unit: http://www.jbrain.com/vicug/gallery/uIEC/bg4
Jim
I thought I had to set up my own power supply. I just plug it into the tape port?
PaulQ
undead vic
Post by PaulQ »
Jeff-20 wrote:I thought I had to set up my own power supply. I just plug it into the tape port?
This is how mine works. A little tricky unplugging it from the cassette deck port, however.
Pedro Lambrini
Can you just hard wire the one connection internally to the cassette port and still use the Datasette without any conflicts or too much draw on the power?
nbla000
Salmon Run
Post by nbla000 »
Pedro Lambrini wrote:Mine was shipped this very morning. Cannot wait! Between this and my forth-coming Mega-Cart I am truly sorted in the world of VIC. :)
Yes, i'm working on a small fix for EasyLoad+ included on Mega-Cart to be fully compatible with uIEC.
I think that Mega-Cart with uIEC is perfect for a very geeky Vic user 8)
Pedro Lambrini
That's good to know. I hope the conflict isn't too much of a hassle for you to fix. By the way, are you calling me a geek! :P
brain
Post by brain »
Pedro Lambrini wrote:Can you just hard wire the one connection internally to the cassette port and still use the Datasette without any conflicts or too much draw on the power?
Yep.
Pedro Lambrini
Yep.
That's also good to know! :)
I think "Yep" and "TOP" (in the picture) combine to make the FAQ.
nbla000
Salmon Run
Post by nbla000 »
nbla000 wrote:Yes, i'm working on a small fix for EasyLoad+ included on Mega-Cart to be fully compatible with uIEC.
The current EasyLoad+ version is fully compatible with uIEC if you disable Turbo first, before to load a file from uIEC you just need to press F5 to disable turbo, that's all.
My next fix just allows to load files from uIEC or any other not supported drive even if Turbo is enabled by using standard kernal routines of course.
PS: Supported EasyLoad+ drives for Turbo are: 1540/1541/1541-II/1541C/1570/1571/1581 and relative clones.
Schlowski
NoMess!
Post by Schlowski »
Nice to know since I ordered my uIEC yesterday :-)
Can't wait for both to arrive!
