Island of Secrets adventure from C64, 40 cols (VIC +24K)
Hello all,
I just played a bit with the C64 version of the funny text adventure "Island of Secrets", which was published as a textbook including the game manual and BASIC listing by Usborne Publishing in 1984.
Eliminating some pokes, text colours, and upper/lower cases, I obtained a VIC-20 version suitable for 40 column software such as FAT-40.
Here you can find the game disk, in-game clues, and a complete map.
The game itself is simple and the parser limited, but I find the atmosphere is good, thanks also to the excellent manual, with comic-style drawings and nice descriptions.
So, have fun, and whenever you find a bug, please report it. I simply took the C64 version and adapted some lines, so I won't be responsible for frustration coming from possible bugs. Remember to XSAVE often!
To play, just set full RAM blocks and
LOAD"*",8
RUN
(40 column mode starts, then)
LOAD"IOS",8
RUN
Sorry for memory requirements, but the 40 col mode itself is RAM consuming. Anyway, I just wanted to play a 40 column adventure, and here we are .
LOAD"*",8
RUN
LOAD"IOS",8
RUN
Oh! This is just AWESOME!
Again: I wonder if we will ever get FROTZ for the VIC-20!
http://frotz.sourceforge.net/
Imagine that with a 40 column emulator! Wheeee!
- Pedro Lambrini
- Mayhem
- High Bidder
- Pedro Lambrini
OK, tested with Mega-Cart using the PET-Loader Utility and it works.
The PET-Loader uses a 40 colums screen and since there aren't strange POKEs, seems that Island of Secrets works.
You may carefully test it by using PET-Loader with a Vic+32K
LOAD"PET",8,1
SYS64802
LOAD"IOS",8
RUN
Using Mega-Cart you need just to select PET-Loader from the utility and load "IOS"
LOAD"PET",8,1
SYS64802
LOAD"IOS",8
RUN
Alternatively, you can download the whole book - including BASIC listing and clues - here (7 MB).Pedro Lambrini wrote:I just tried to download the manual but I jsut get a 2k file. I've tried with Opera and Firefox...don't know what the problem is.
Thanks, hope to see more 40 col adventures in the future (as Ral-Clan said, Frotz would be a great achievement for the VIC community )Pedro Lambrini wrote:I should say great work there orion70!
Excellent, too bad it won't be on the Mega-Cart (I'm joking of course, I know how many modifications to the software list you had to do).nbla000 wrote:OK, tested with Mega-Cart using the PET-Loader Utility and it works.
It would be nice. Also, a 40 col version of the Frotz adventure interpreter would be much better than its 22 col counterpart!Mayhem wrote:Now if someone can produce a self booting version (ie. load the game automatically after 40 column mode program is loaded) I can put it in GB20...
- Pedro Lambrini
Frotz would be just too good to be true, wouldn't it? Suddenly the library of text adventures for the VIC would go through the roof! Although, a fair few of them probably would not fit into the VIC's memory limitations even with 32k it would still be an achievment and a half to get Frotz off the ground...
1 - Here http://rapidshare.com/files/192001307/I ... s.zip.html you have a copy in 1 part PRG. with a little problem, for center the image you must use NTSC screen.Mayhem wrote:Now if someone can produce a self booting version (ie. load the game automatically after 40 column mode program is loaded) I can put it in GB20...
I only added the first and the second program of the disk and this seem works OK
2 - Can someone put a link to Frotz?. I can try to create one part program too, but I dont have this program in my colection
- Pedro Lambrini
ral-clan posted a link earlier in this thread but here it is again:
Good luck!
Good luck!
- Mayhem
- High Bidder
Ah hah hah... never underestimate the abilities of the people on here to get things sorted. Seems to be working goodformater wrote:1 - Here http://rapidshare.com/files/192001307/I ... s.zip.html you have a copy in 1 part PRG. with a little problem, for center the image you must use NTSC screen.
- Pedro Lambrini
For PAL users I added a line in the second partorion70 wrote:Thanks formater, very well done .
A PAL version to play with on a real PAL-land VIC would be just perfect .
1 POKE36864,14 : POKE36865,40
You can download the modified program here: http://rapidshare.com/files/193950876/I ... _.zip.html
