Adding paddle support to Spacesnake?
- Pedro Lambrini
How hard would it be to add paddle support to the Commodore game Spacesnake? It's always been one of my favourite games and when I was wee always wanted to play it with my under-used paddles...
Not to Hi-jack your thread. I've been thinking about a related project. Programming for Alternate Controllers
- Pedro Lambrini
Oh, you so did hijack my thread. Thief! :pJeff-20 wrote:Not to Hi-jack your thread. I've been thinking about a related project. Programming for Alternate Controllers
As far as the coding goes, then, it's maybe out of my league...I don't know the first thing about ML. I might have to come back to this idea in another 26 years!
- Pedro Lambrini
Arma's Tapes has it:nippur72 wrote:any link to download SpaceSnake ?
http://www.6502dude.com/cbm/vic20/arma/staps.html
It's listed as two words but it should be Spacesnake.
As far as changing game-play goes: I think it might have an effect if it was treated as an analogue controller but if it was just giving signals for up and down it wouldn't change a thing. I've just always thought the paddles as a controller would suit this game. To be honest, I think that paddles are totally underused - I don't see why all Space Invaders, Breakouts and a multitude of other genres don't use them ubiquitously.
if someone need, i've fixed space snake some time ago to work from disk too, get it from this disk with other fixes.
There is an HANDIC cartridge present on Mega-Cart with the same name but it's a similar game even if it uses paddles.
No, i confirm you that they are different, in the tape version the snake moves from left to right while in the cart version the snake moves from up to down and may use paddles too.carlsson wrote:Similar? I thought the tape and cartridge versions were identical?
You may download the Zimmers cart image used for Mega-Cart too.
http://www.zimmers.net/anonftp/pub/cbm/ ... 0Snake.prg
- Pedro Lambrini
- Mayhem
- High Bidder
Pedro, are you sure paddles are suited for that type of game? I've played it a little with keyboard and seems very sensitive; with paddles it can even be worse.
Also, Lee mentioned Space Snake being mix of basic and ML, but the version I've downloaded seems to be entirely in ML (it has a single SYS). What is the correct version?
