Vic 20 startup time
Vic 20 startup time
Hi I just got a question
my Vic takes about 15 seconds to startup is this normal ? this seems a bit long to me
otherwise I cannot see anything wrong with it
and if this is not normal , any Ideas as to why it wil do that ?
I have not seen a Vic-20 take 15 seconds to start.
However, I have seen variations in amount of time to start between machines.
I think the longest, that I have observed, may be in the order of a 2 or 3 seconds before screen display.
It could be a problem with the RC circuit(s) before the 555 that switches the reset line. Cold solder perhaps.
The start time also slightly depends on the memory configuration. More memory takes more time in the RAMTAS routine to test. But, as 6502dude pointed out, that time doesn't exceed ~3 seconds.
- Mayhem
- High Bidder
If you have a multimeter, check VCC and make sure it is 5.0 vdc +/- .1vdc
Then check if AC ripple on VCC line exceeds .1 vac
On spec, I would change the electrolytic filter capacitors in power supply.
These should be 4,700uf and 100uf units for Vic-20 with two prong 9VAC adapter.
Vic-20 is 20+ years old and the power supply electrolytic capacitors really should be replaced as part of preventative maintenance anyway, especially if unit has been in storage for extended period of time.
thanks 6502 dude
I think you onto something with regards to the caps
it might just be the devils!
hmm time to wield my soldering iron (cue dramatic music)
while I am at it I think I will add some heatsinks to the IC's
juuust in case..
juuust in case..
I am not an electronics expert at all....I will defer to 6502dude....but my first reaction on reading your problem was that capacitors in the power supply might be slow to charge.
I have an old 1525 printer that can't drive the printhead until it's been on for a few minutes. I'm suspecting capacitor problems for that too.
So please let us know if a capacitor change helps things. Thanks.
I am certainly not an expert.ral-clan wrote:I am not an electronics expert at all....I will defer to 6502dude....
Sounds like power supply capacitors may be your issue as well.ral-clan wrote:I have an old 1525 printer that can't drive the printhead until it's been on for a few minutes. I'm suspecting capacitor problems for that too.
Here is simple chart of electrolytic capacitors failures:
If you have significant decrease in capacitance (which will occur over time), the power supply will not be able to supply sufficient current to drive the print head.
