I have. 2 Prong PAL VICs take an unusually long time to startup. I have one and it does the same thing.6502dude wrote:I have not seen a Vic-20 take 15 seconds to start.
This was discussed with Shaughn Bebbington on Lemon64.
I disagree.6502dude wrote:Try changing these:
Most probable culprit is the big grey one (4,700uf)
Changing little blue one (100uf), is not a bad idea while you have soldering iron out.
With a scope you can clearly see the reset line held low. This can only be caused by the 555 timer. It has nothing to do with capacitor charging time.
Unlike HiFi audio amplifiers, the VIC is not equipped with a delay system that waits for capacitors to charge before activating the system.
