VIC-20 Cartridge Case Reproduction Plans
- Schema
- factor
I've been thinking, as I want to make some carts too, that it may be cheaper if you make a design that has two halves that are exactly the same, thus requiring only one mold.
i.e. on the left side you have a clip and on the right a socket, such that if you flip it over the clip and socket line up on either side.
Any special differences between the sides could be implemented with break off bits.
As a quick update, a forum member here has been helping me by creating a 3-D CAD model of a case. His first attempt would not export in the right format for the molding company, but a second try appears to be coming along better.
It's still a long ways off, as the 3D model is needed to get a quote, and then one has to decide how to finance this.
Jim
Jim
