DigitalQuirk wrote:eslapion wrote:
This link in no way says how to modify a two pronged VIC to work with a C64 or C128 power supply...
Clearly then, I was not referring to the two pronged Vic, was I?
Then its my feeling you were not answering Ral-clan's question.
eslapion wrote:In my opinion, a C128 PSU is much better than an original brick but it is not as safe and as reliable as a modern switching wallwart.
Please explain in what way is the Commodore 128's switching power supply less safe than a cheap wall wart switching power supply.
When I say less safe, I don't mean for you or your house. I mean it has a greater likelyhood of damaging your machine. Altough cases of C128 PSUs destroying the machine they power are considerably fewer than with original bricks, just like with disaligned 1571s, there are a couple.
When the C128 PSU was designed, switching PSUs were in their infancy.
Good quality MOSFETs with low "ON" resistance that dissipate little heat weren't available. Many lower power PSUs didn't even use MOSFETs and many of them had a very poor
power factor because they consume electrical current in a very irregular manner.
As I recently illustrated in a post addressed to Groepaz on Lemon64, the power factor of C128 PSUs sold in north america is very poor.
While the level of efficiency of a good switcher is around 90%, the efficiency of both C128 PSUs I have here is barely above 50%. Comparatively, the efficiency of the C64 brick is around 30%. More heat always contributes to shorten the lifespan.
Also, the feedback systems of these things is fully based on analog chips that were slow to react. If one of them fails, it can briefly expose the machine to a much higher voltage than the rated output.
If you look at more modern switching PSU controllers like the LM3524 or TL494, these use a combination of analog and digital circuitry which forces a shutdown in specific conditions.
Damage to the powered device can also occur because of other reasons I mention below.
eslapion wrote:Before you blast me with all the junk you're used to, I would like to point out that ALL power supplies eventually fail and they are the greatest single source of computer failure. What really matters is not IF a power supply fails but what happens when it does. A modern power supply made with quality parts will NEVER damage the computer of electronic apparatus it powers when it dies, it will just shut itself off...unless it been opened and tampered with.
Are you suggesting that the Commodore 128's switching power supply will not behave in this manner?
It can and it has. Much less frenquently than Commodore bricks but like I said, it has happened.
Sometimes this is not necessarily attributable to a design flaw. C128 PSUs have venting holes. Through the years, all sorts of dust, insects, liquids can infiltrate through those venting holes and affect the performances of components inside. In such a case, the simple fact that a switching wallwart has less age can make it more reliable and safer for your Commodore computer.
There is also the classic problem with aging electrolithic capacitors... no PSU is immune to that.
eslapion wrote:Switching wallwarts are now used to power (or recharge) everything from cell phones and PDAs to expensive electronic instruments. We use wallwarts to recharge multi thousand dollars Fluke portable scopes as well as powering FPGA development boards. Just like any other PSU, they fail every once in a while and we get them replaced but they NEVER damaged any equipment, or represented a fire hazard in any way or injured anyone.
That's nice. I've never heard of a Commodore 128 PSU damaging any equipment or representing a fire hazard or injuring anyone; so I'm still unclear as to how it's less safe.
Injuring anyone or causing a fire hazard, I have never heard either. Damaging a C128 and destroying a 1750 REU, I have heard...
Power supplies used in PCs and clones of that era have done that too. They use pretty much the same SCR/BJTs technology. A 22 y.o. power supply is... a 22 y.o. power supply, even if its a better one.
As said above, its not less safe to you. Its less safe to your equipment.
That being said, according to my experience, its still much safer than an original brick.
eslapion wrote:A heat sink CAN save a chip from burning out. Does that mean YOU should not consider other causes? I hope not.
I certainly never said you shouldn't.
You seem to suggest it's the only reason why it fails:
I really hope not.
eslapion wrote:Its rather monolithic thinking to assume a heat sink (...not heat sync...) will always save your chip no matter what happens because it can prevent it from suffering damage caused by heat.
Perhaps you and I are talking about different things. Is your heat "Sink" like a kitchen sink, or more like a bathroom sink?
Its more like
that...
It's common for you to state that a person's 6560 failed due to heat; you do this all the time. See quote above for reference.
I firmly believe the main cause of 6560 failure is prolonged exposure to heat.
Its not the only one.
Since the original MOS 6502 and MOS 6522 VIAs used in the VIC-20 and 1541 drives both use the same NMOS technology, why do they fail much less often comparatively?
The 6560 can fail for the same reasons as the 02s and VIAs, such as static electricity discharge or short circuits/innapropriate voltages caused by failed or failing external components yet the 6560 fails considerably more often.
BTW, if your 6560 would have been damaged by a higher voltage from the PSU, its likely the VIAs or 6502 would also have suffered damage. All these chips use the same technology and all run on the same 5V source.
I'm not denying that excessive heat causes failure. What I'm saying is that there is a lack of evidence demonstrating that the 6560 in the Vic 20 suffers from levels of heat to cause it to fail. Unless you're suddenly an expert in thermology, what independent source is there to substantiate your claim?
The type of doping used in Commodore's NMOS technology is well known. It was also used in other chips of this era. Considering the properties of this type of semiconductors and the impact of temperature on it is well documented, all you need is a mean of verifying its temperature while it is operating, preferably with the VIC case closed and the metal shield in place.
My favorite tool for doing that is a K type thermocouple. Using that, I discovered that the 6560 operates at "borderline" temperatures. Did you ever bother to check the current drwn by the 6560? Its very interesting. Apply V*I=P and you could have a nice surprise...
Another chip that is often overlooked but that also operates at potentially damaging temperatures is the 64's/128's SID, specifically the 6581.
The 8580 does not dissipates as much heat.
