perhaps I should try jumpering it? change the loading address? it already doesn't work so I can't see much harm in it...
carlsson wrote:The jumper indeed sounds like where you select which memory block the cartridge should load into. Does it look like somebody has hacked it?
Is the ROM chip socketed? In worst case, the circuit board may be reusable if the ROM itself has gone bad. It depends a little if all "fingers" on the connector still are present or only those required for the game remain.
No it's not socketed but I did confirm the jumper is to change the BLK address from $A000 to $6000 so that probably wont help anything.
It's too bad but I guess I could unseat the chip and put in sockets for later experimentation...
carlsson wrote:Is the ROM chip socketed? In worst case, the circuit board may be reusable if the ROM itself has gone bad. It depends a little if all "fingers" on the connector still are present or only those required for the game remain.
