There is a way to connect a vic 20 with a standard pc monitor?
Thanks!!
VIC 20 To PC Monitor.
At least if you have a TV card in your PC you should be able to connect your VIC-20 to that one and then display the captured image on the monitor. I've read about a guy who does so, having a secondary PC entirely for video capture. A bit impractical perhaps, but it works.
I believe there are standalone composite to VGA converters too, but I've no experience of those
Thanks a lot!!!!carlsson wrote:At least if you have a TV card in your PC you should be able to connect your VIC-20 to that one and then display the captured image on the monitor. I've read about a guy who does so, having a secondary PC entirely for video capture. A bit impractical perhaps, but it works.
I have never used one, but here is an idea:
http://accessories.us.dell.com/sna/prod ... 6#Overview
I suspect there is something like this for PAL market.
Yes, I have a composite to VGA adapter (AverMedia TVBox 5 (its also a TV tuner)) and have used it to connect a CD32 and Dreamcast to a VGA LCD monitor. I haven't tried connecting the Vic20 but it should work fine too.carlsson wrote:At least if you have a TV card in your PC you should be able to connect your VIC-20 to that one and then display the captured image on the monitor. I've read about a guy who does so, having a secondary PC entirely for video capture. A bit impractical perhaps, but it works.
Steve
Re: VIC 20 To PC Monitor.
I use this:mysecretgarden wrote:There is a way to connect a vic 20 with a standard pc monitor?
Thanks!!
http://www.viewsonic.com/support/access ... tvisionn6/
Bought it early 2006 so I don't know if it is still being made but I gotta tell you its just plain great.
