I used the search function and couldn't get a straight answer from it, so I might as well ask here... has anyone developed a peripheral for the VIC-20 that would allow it to save content to an SD or Compact Flash card? I'm asking because I've got 20+ year old VIC games I designed which I'd like to back up to a more permanent/emulator friendly storage device. The ability to save them as PRG files and play the games on MAME or VICE would be a HUGE plus.
SCREW BEAR
Bear is so startled that he falls off cliff.
You can use a 1541 Ultimate in external mode or, more ideally something like the uIEC. It's quite affordable ($50 or $75 depending on the model you choose).
Considering the technical information available to me, I believe it would be possible to plug the 1541Ultimate directly into the cartridge port of the VIC-20, if only to provide it with power.
