Any idea what's wrong with my picture? This Vic has been in storage for many years, and now I'm hooking it back up to get it back to its old self. When I turn it on, I get nothing but a grey screen with a blue/green border. No text. Turning it on with a cart in has the same effect.
Is something fried in there?
Resurrecting my Vic
As per Ray Carlsen's text, it sounds like the Basic ROM but then many game cartridges should play anyway.
http://personalpages.tds.net/~rcarlsen/cbm/vic20.txt
First off - Hi. First post here.
Secondly, I'd say check your CPU above anything else. If you're getting a border and background correctly it sounds like your VIC chip is ok, and your RAM probably is too otherwise you'd get corrupt text on the screen.
You might also want to check that your CPU is getting a clock signal - if it isn't, then it won't do anything so it won't be running your ROM - hence no text.
I'm not so hot on VIC hardware so my information is limited.. does anyone have a ROM disassembly anywhere? That might help....
Ian Gledhill
ian.gledhill@btinternit.com except it's a nEt not a nIt
www.mutant-caterpillar.co.uk/shop/ for repairs and hardware/software
Ian Gledhill
- not necessarilySpirantho wrote: If you're getting a border and background correctly it sounds like your VIC chip is ok
- actually defective ram could cause problem of no characters on display., and your RAM probably is too otherwise you'd get corrupt text on the screen.
- clock is good, otherwise Vic-20 would never get to the point of intializing registers in 6560 and creating a border display with correct colours.You might also want to check that your CPU is getting a clock signal - if it isn't, then it won't do anything so it won't be running your ROM - hence no text.
Richard Cini posted rom disassembly years go online.does anyone have a ROM disassembly anywhere? That might help....
But why bother? This is a hardware problem.
Not necessarily, no... but in my experience if a video chip goes kablooie you know about it - a completely black screen usually. In this case it sounds like it's probably ok. Probably, not definitely.6502dude wrote:- not necessarilySpirantho wrote: If you're getting a border and background correctly it sounds like your VIC chip is ok
Yes, it could... but again in my experience it's unlikely.- actually defective ram could cause problem of no characters on display., and your RAM probably is too otherwise you'd get corrupt text on the screen.
The VIC uses its memory for the frame buffer doesn't it? So if the memory is knackered you'd usually get a screen full of "@" signs or something, at least if it's like the PET (and I think I've seen this on a +4 or something).
Fair enough. If those are set by the ROM then the clock is good and the CPU is at least functioning partially.- clock is good, otherwise Vic-20 would never get to the point of intializing registers in 6560 and creating a border display with correct colours.You might also want to check that your CPU is getting a clock signal - if it isn't, then it won't do anything so it won't be running your ROM - hence no text.
Why bother? Because looking at the ROM disassembly you can see at what self-checks the ROM does. We know it's failing somewhere between the initial registers to the VIC chip being set and the actual BASIC prompt, so it may help to know exactly what the ROM checks. If, for example, it checks any of the support chips and halts when there's an error, we know something else could be at fault too.Richard Cini posted rom disassembly years go online.does anyone have a ROM disassembly anywhere? That might help....
When troubleshooting hardware I find it's best to know the most you can about the hardware and the software.
In this case the first thing to do though is to reseat the CPU and VIC chips and see if that fixes it.
A little addendum: In a thread about black screens just below this one in the forum, I found this:
I'd defintely check the CPU and its clock signal then, if that's correct.Jogi once told me every VIC-20 will produce a empty border screen if only the VIC is still in the board
Ian Gledhill
Ian Gledhill
Self-checks: None. There is no room for it. In the C64 the only thing checked is determining PAL/NTSC by checking what raster lines appear in the VIC-II so that the right RS232 dividers are set. In VIC20 there is no such code AFAIR.Spirantho wrote:Because looking at the ROM disassembly you can see at what self-checks the ROM does.
What happens at boot: (from memory)
1) init stack pointer, init peripheral chips
2) determine functioning BASIC RAM start and size
3) relocate screen depending on BASIC RAM location
4) prompt
If you get the correct border colors, the 6502 should be okay and KERNAL ROM at least partially functional. Stack or zero-page RAM can be bad, or KERNAL or BASIC ROM's fail.
If any cartridge game works, RAM is probably okay. If some cartridge games fail (but some work), it's probably BASIC ROM (or maybe KERNAL ROM).
Anyway, more information is needed.
