Maximum display size PAL and NTSC, post your pics here
I've written a small utility program to check the maximum display size of real hardwares (TV sets or Monitors).
If you like, download it from here and run on your real VIC-20.
Use cursor keys to center the screen and +,-,<,> to increase/decrease the screen size. "I" key turns on/off the interlaced mode. R key restores the original screen values.
Don't forget to post a picture, the datas showed in the screen are useful to game developers, so they can write NTSC and PAL compatible programs!
I'll start with a picture of my system, a 14" TV set from "SINUDYNE":
[/url]
[/url]
Hey, I wrote a program just like yours once:
http://user.tninet.se/~pug510w/datormuseum/overscan.zip
Your link doesn't work.
Now it did...
a typical example of Convergent evolutionBoray wrote:Hey, I wrote a program just like yours once
BTW, do you have any pics? I'm interested in NTSC values...
Mine seems to be quicker... Convergent design... not evolution... My program ceirtainly didn't write itself by chance over millions of generations... I don't have any NTSC machine... And my Philips monitor has knobs to tweak the display to what you want... But I will take a picture of my display anyway because I think this is a good idea (of course I would, wouldn't I ). I think I only got Vic User to post his values when I posted my program here...nippur72 wrote:a typical example of Convergent evolutionBoray wrote:Hey, I wrote a program just like yours once
My normal vic display:
Big display on my normal monitor setting:
Oversized display on my normal monitor setting:
Biggest display I could get on my monitor:
Standard size on this monitor setting:
With my biggest setting, I got 224x280 = 62720 pixles. A c64 has a display of 320x200 = 64000 pixles.
So you mean there is a purpose in evolution? Who's purpose?DigitalQuirk wrote:For the record, evolution isn't chance, thanks to something called natural selection.Boray wrote: Mine seems to be quicker... Convergent design... not evolution... My program ceirtainly didn't write itself by chance over millions of generations...
My normal vic display (Commodore 1084s):
Big display Interlace off (31x25 is better but i may adjust the display for 31x26):
Big display Interlace on (31 rows x 25cols is better IMHO):
It's meaningless to talk about purpose in natural processes, although we as self-reflecting sentient beings have a tendency to look for purpose and meaning in everything.Boray wrote:So you mean there is a purpose in evolution? Who's purpose?DigitalQuirk wrote:For the record, evolution isn't chance, thanks to something called natural selection.Boray wrote: Mine seems to be quicker... Convergent design... not evolution... My program ceirtainly didn't write itself by chance over millions of generations...
For an introduction to the role of chance in evolution see the talk.origins FAQ.
Bacon
what is the effect of interlace, I can't see any difference on my TV set.
And also, why your bottom colour memory looks all black while mine is random? Did you clear it by hand?
A small tip when taking pictures of CRT displays: to avoid the horizontal black strip use a very low shutter speed on your camera (e.g. 1/8 second). This because with fast shutter speeds you actually capture the raster beam painting on the screen; the black zone is the part of the previuos video page that is dropping in luminosity and that needs to be "refreshed".
If your camera doesn't allow to change the shutter speed, but has "presets", then look for "night scene" or "fireworks" preset.
Low shutter speeds require the use of a tripod or of a very steady hand. You can also avoid the spotlight mirrored on the screen by turning the flash off. If the overall pictures (except screen) is too dark you can take two exposures and merge them in photoshop (like I did in my picture).
Sorry for the small OT.
