CBM floating point data type
a question for the math wizards (Mike are you reading?)...
What's the best way to encode a number in the CBM floating point format ? I need to do that in my cross-compiler tool, so I need a sort of algorythm to convert a C++ double or float into the 5 bytes of the CBM format.
After investigation I've found that VIC-20 encodes numbers as powers of two. The first byte is the exponent, then a bit sign follows, and then mantissa, for a total of 5 bytes. The formula should be something like this (but I don't swear on it):
number = (-1^S) * 2^(E-127) + (1 + M / (2^33))
So where to start for a conversion routine?
BTW, the $DDD7: Print (FAC) as ASCII string. routine listed in the thread ROM calls and other tricks prints without sign.
There is:
$D7B5: Convert string starting at (INDEX1) of length (A) to FLPT value in (FAC).
with:
INDEX1: $0022-$0023, First utility pointer,
A: Accumulator,
FAC: $0061-$0066, Floating-point Accumulator (FAC).
BTW: (-1^S) will always give -1 as result. The power operation binds more tightly than sign inversion. You surely meant (-1)^S .
with:
A: Accumulator,
yep, but I need something outside the VIC-20: I would add it to my cross compiler tool (C++ written) as I'm extending it to support floating point operations.Mike wrote:$D7B5: Convert string starting at (INDEX1) of length (A) to FLPT value in (FAC).
BTW: is it more convenient to encode starting from a string (e.g. processing each digit with adds and *10 muls) or from C++ IEEE float format? Thank you for any help, I would like to translate my 3d function plot type-in into assembler.
Mike wrote: BTW: (-1^S) will always give -1 as result. The power operation binds more tightly than sign inversion. You surely meant (-1)^S .
* IEEE double precision to CBM 5 byte float conversion
* written 2008-06-19 by Michael Kircher
#include <stdio.h>
#include <math.h>
int main()
double number=3.141592653589793;
double mantissa;
int exponent;
unsigned long cbm_mantissa;
unsigned char cbm_exponent;
mantissa=frexp(number,&exponent);
cbm_mantissa=(unsigned long)(4294967296.0*fabs(mantissa)) & 0x7FFFFFFF + 2147483648*(mantissa<0);
cbm_exponent=128+exponent;
printf("IEEE double precision value = %.15g\n",number);
printf("CBM 5-byte format: $%.2X $%.2X $%.2X $%.2X $%.2X\n",
cbm_exponent,
(unsigned char) (cbm_mantissa >> 24),
(unsigned char) (cbm_mantissa >> 16),
(unsigned char) (cbm_mantissa >> 8),
(unsigned char) (cbm_mantissa));
return(0);
WOW
double WOW
and a big thank you! Now I can add support to floating point to my compiler tool! Can't wait to test it!
Here is a small program taken from VIC20 user guide that calculates the first digits of PI. I do the same calculation first in basic and then in machine language using the floating point kernel routines and thanks to the support of the CBM float data type.
Results of 2500 iterations:
BASIC: 00:00:31 seconds
ML: 00:00:17 seconds
Here is the code. Notice the "float" keyword among all other language extensions.
processor 6502
include "floatlib.lm"
include "vic20.lm"
include "macros.lm"
org $1001
basic start compact
10 TI$="000000"
20 PI=0
30 FORC=1TO10001STEP4
35 PI=PI+4/C-4/(C+2)
50 NEXT
55 PRINT PI
60 PRINT TI$
70 TI$="000000"
80 SYS {main}
90 PRINT:PRINT TI$
basic end
C float 0.0 ; variables
PI float 0.0 ;
ZERO float 0.0 ; float costants
ONE float 1.0 ;
TWO float 2.0 ;
FOUR float 4.0 ;
MAX float 10001.0 ;
main:
mov fac, ZERO ; PI = 0
mov PI, fac ;
mov fac, ONE ; C = 1
mov C, fac ;
forstart:
mov afac, FOUR ; tempf1 = 4/C
ldx #$00 ;
div afac, C ;
mov tempf1, fac ;
mov fac, C ; tempf2 = C+2
add fac, TWO ;
mov tempf2, fac ;
mov afac, FOUR ;
ldx #$ff ;
div afac, tempf2 ; fac = -4/(C+2)
add fac, tempf1 ; fac = fac + tempf1 + PI
add fac, PI ;
mov PI, fac ;
mov fac, C
fcmp MAX
if a<>#00 then
add fac, FOUR
mov C, fac
jmp forstart
end if
mov fac, PI
print fac
rts
This is about the best you could expect. You've effectively eliminated the number conversions, variable lookup, and building the evaluation tree 'on-the-fly' - leaving the floating point division as dominating factor. And of course the Gregory-Leibniz formula calculating pi=4*arctan(1) as series expansion isn't the most efficient way to do this.nippur72 wrote:Results of 2500 iterations:
With the function plot example you posted in another thread, you've got SQR(), and SIN() inside, so the gain from 'compiling' it might even be less. Did you try it?
The built-in SQR() can be replaced by Heron's algorithm for a 4 times speed gain.
I tried to "compile" it, but it became too complex so I had to give up. It was an hell of "store fac here", "take afac there" and so on. I was very disappointed because I believed that with my macro language tool the conversion would have been a trivial thing, while in reality it revealed a very complex task.Mike wrote:With the function plot example you posted in another thread, you've got SQR(), and SIN() inside, so the gain from 'compiling' it might even be less. Did you try it?
Perhaps I now need an "expression compiler"...
P.S. yes the sum is really slow converging, after 2500 iterations only few digits are exact. And there's a typo in the reference guide, a "+" in place of an "-" (at least in the electronic version).
You could wrap the relevant functions, so that they don't operate on FAC, and AFAC, but instead on the top(most two) element(s) of a self-built number stack. And then use Reverse Polish Notation, as in FORTH.nippur72 wrote:Perhaps I now need an "expression compiler"...
that should be quite easy, considering that most (all?) of the functions take only one parameter and produce only one numeric result.Mike wrote:You could wrap the relevant functions, so that they don't operate on FAC, and AFAC, but instead on the top(most two) element(s) of a self-built number stack.
The real trouble is making the expression parser: I wrote three or four in the past (in different languages), but never managed to make them perfect (except the one that was made using Lex/Yacc).
Addition, subtraction, multiplication, and division can very well considered as functions taking two parameters.nippur72 wrote:that should be quite easy, considering that most (all?) of the functions take only one parameter and produce only one numeric result.
I know. But if you use RPN (instead of infix) the parser reduces to "get the next token", and "decide what to do with it". The expression tree really is built by the programmer. Of course one must be used to RPN ...The real trouble is making the expression parser: I wrote three or four in the past (in different languages), but never managed to make them perfect (except the one that was made using Lex/Yacc).
For example, line 35 in your program could be expressed thus:
PI 4 C / + 4 C 2 + / -
PI [PI]
4 [PI] [4]
C [PI] [4] [C]
/ [PI] [4/C]
+ [PI+4/C]
4 [PI+4/C] [4]
C [PI+4/C] [4] [C]
2 [PI+4/C] [4] [C] [2]
+ [PI+4/C] [4] [C+2]
/ [PI+4/C] [4/(C+2)]
- [PI+4/C-4/(C+2)]
Re: CBM floating point data type
Resurrecting this old post, for an updated version of Mike's routine, translated to TypeScript/JavaScript:
function CBMFloat(S: string): string {
var num: double = Number(S);
var mantissa: double;
var exponent: int;
var cbm_mantissa: ulong;
var cbm_exponent: uchar;
[mantissa, exponent] = frexp(num);
cbm_mantissa = (4294967296.0 * fabs(mantissa)) & 0x7FFFFFFF + 2147483648 * ((mantissa < 0) ? 1 : 0);
cbm_exponent = 128 + exponent;
if (num == 0.0) {
cbm_exponent = 0;
cbm_mantissa = 0;
var v = [
hex(cbm_exponent),
hex(cbm_mantissa >> 24),
hex(cbm_mantissa >> 16),
hex(cbm_mantissa >> 8),
hex(cbm_mantissa)
return v.join(", ");
function frexp(value: double): [double, double] {
var ret = { mantissa: 0, exponent: 0 };
if (value == 0.0 || value == -0.0) {
return [ret.mantissa, ret.exponent];
if (isNaN(value)) {
ret.mantissa = Number.NaN;
ret.exponent = -1;
ret.mantissa = value;
ret.exponent = 0;
var sign = 1;
if (ret.mantissa < 0.0) {
sign=-1;
ret.mantissa = -(ret.mantissa);
while (ret.mantissa < 0.5) {
ret.mantissa *= 2.0;
ret.exponent -= 1;
while (ret.mantissa >= 1.0) {
ret.mantissa *= 0.5;
ret.exponent++;
ret.mantissa *= sign;
function hex(n: number): string
n = n & 0xFF;
var s = "0" + n.toString(16);
s = s.substr(s.length - 2);
s = s.toUpperCase();
return "$" + s;
- Occupation: farmer
You have to LDY #$01 before calling $DDD7, or, alternatively, you JSR $DDDD before calling $CB1E.BTW, the $DDD7: Print (FAC) as ASCII string. routine listed in the thread ROM calls and other tricks prints without sign.
