P00 to PRG?
- Mayhem
- High Bidder
P00 to PRG?
I've got a bunch of program files in P00 format... now Vice will read them fine but I'd like to convert them into PRG if possible. Any easy way?
In VICE under Peripheral settings, you can sett it to read P00 files, but write .PRG files (Mark "Read" but unmark "Write"). You can also set this differently for different devices 8,9 etc...
Re: P00 to PRG?
I use Star Commander (the link doesn't work at the moment), you may send me the files, if you want.Mayhem wrote:I've got a bunch of program files in P00 format... now Vice will read them fine but I'd like to convert them into PRG if possible. Any easy way?
- Mayhem
- High Bidder
- Mayhem
- High Bidder
I might need a newer version StarCom then... I tried doing that originally and it wasn't having anything of it to let me look inside... told me the file image was invalid. But the P00s load and run fine in Vice though. Anything to do with the fact these are Vic20 P00 files...?
- Mayhem
- High Bidder
Re: P00 to PRG?
IIRC the P00 is nothing more then a PRG but with 26 extra bytes at the start with some info.Mayhem wrote:I've got a bunch of program files in P00 format... now Vice will read them fine but I'd like to convert them into PRG if possible. Any easy way?
___
/ __|__
\ \__|_\
\___| URL: www.baltissen.org
- Mayhem
- High Bidder
- Mayhem
- High Bidder
Curiously enough it may not have applied to these, I'm not sure. The guy who does DirMaster was a bit curious why the conversion to PRG didn't work when I was attempting it, and so requested some of the P00 I was using. I'll wait to see what he says on the matter.
