I tried to find a cartridge version of Scram 20 to be able to squeeze a scramble clone into my multicart...
I found a few, none of them seemed to work and were missing the start screen, one wasn't padded to 4kB.
I got hold of a .tap image (well several but they looked as if the were the same file - same sizes and so on) but it was cracked and had some graphics altered.
I sat tonight and worked my way through the code and made a .d64-file of it all. No missing pieces as far as I can tell and no strange graphics with signatures...
Uploaded it here if someone likes to get it:
http://www.megafileupload.com/en/file/5 ... 0-d64.html
Now I'm about to make a cartridge version... it shouldn't take as long.
Does anyone know of any other scramble like game not more than 8kB?
Scram 20
- e5frog
- Vic 20 Nerd
- Website: http://channelf.se
Scram 20
- e5frog
- Vic 20 Nerd
It's done.
Download this 4kB wonder cart here:
http://www.2shared.com/file/3047625/348 ... ram20.html
No crunching used...
Not that it's a very neat game, it's very jerky, and difficult...
The difference between my version and other cart versions I have seen is that the intro screen is there and the game is working! Just hold F1 to start.
Here's the code I used to compile it:
; Fredric Blåholtz
; 4kB autostarting cartridge
; version from .tap-file
; of
; SCRAM 20
; Assembled in March 2008
; dasm game.asm -f3 -ogame.bin to compile
processor 6502
dest = $1001 ; destination adress
org $a000
; Startup code for autostart
.word inits ; Entry point for power up
.word restore ; Entry point for warm start (RESTORE)
.byte "A0" ; 'A0CBM' autoboot string
.byte $C3,$C2,$CD
inits:
;Kernel Init
jsr $FD8D ; RAMTAS - Initialise System Constants
jsr $FD52 ; Restore Kernal Vectors (at 0314)
jsr $FDF9 ; Init I/O
jsr $E518 ; Init I/O
;BASIC Init (Partial)
lda #8 ; Set screen colors
sta $900F ; black+black
jsr $E45B ; Init Vectors
jsr $E3A4 ; Init BASIC RAM
jsr $E404 ; write start text
; show intro screen
draw_scram:
ldx #$00
print1:
lda plot_scram,x
beq print1.end ; branch when data is 0
jsr $ffd2
inx
jmp print1
print1.end:
ldx #$00
print2:
lda plot_rest,x
beq print2.end ; branch when data is 0
jsr $ffd2
inx
jmp print2
print2.end:
; delay for approximately 5 s
lda #0
ldx #0
ldy #0
jsr $ffdb
wait:
lda $a1
beq wait
; copy data to $0000
copy_0000:
if 0
; VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
ldx #$ff
copyloop:
inx
lda start_0000,x
sta $00,x
cpx #$8f
bne copyloop
; AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
endif
; set irq
lda #$c2
sta $0314
lda #$03
sta $911e
; load game
copy_game:
if 0
;Write initial data:
lda #0
sta $1001
sta $1002
lda #$50
sta $1003
ldx #26
ea_loop:
lda #$EA
sta $1004,x
dex
bne ea_loop
endif
; actual program data
ldx #14 ; number of 256 byte pages to copy
lda #<start_game ; lower byte of address
sta $FB ; store in $00FB
lda #>start_game ; upper byte of address
sta $FC ; store in $00FC
lda #$1F ; lower byte of address
sta $FD ; store in $00FD
jsr rest_of_copy
; game loaded, set correct fast page data
copy_0000_2:
ldx #$ff
copyloop_2:
inx
lda start_0000,x
sta $00,x
cpx #$8f
bne copyloop_2
;write 43 zeroes, start on $8F
ldx #44
zeroloop:
lda #0
sta $4D,x
dex
bne zeroloop
; start game!
jmp $101F
; Copy data, parameters already set
copy_data:
lda #<dest ; lower byte of address
rest_of_copy:
lda #>dest ; upper byte of address
sta $FE ; store in $FE
loop2:
ldy #$00 ; Y = 0
loop1:
lda ($FB),Y ; A = contents of $00FB plus offset Y
sta ($FD),Y ; $00DF + offset Y = A
iny ; increase Y
bne loop1 ; Branch on Result not Zero to L1
inc $FC ; increase value at $00FC (upper byte of start address)
inc $FE ; increase value at $00FE (upper byte of dest. address)
dex ; X = X - 1 (decrease pages left to copy)
bne loop2 ; Branch on Result not Zero to L2
rts
; Handle the RESTORE key
restore:
jmp $FEC7 ; Continue as if no cartridge installed
; Game data
if 0
; VVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
start_intro:
incbin "games/Scram20/Scram20-intro.bin"
end_intro:
; AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
endif
start_game:
incbin "games/Scram20/Scram20-game.bin"
end_game:
start_0000:
incbin "games/Scram20/Scram 20 at $0000.bin"
end_0000:
; Define some common PETSCII codes
; http://sta.c64.org/cbm64petkey.html
CLRHOME = $93
clr = $93
RVSON = $12
rvon = $12
RVSOFF = $92
rvof = $92
CR = $0D
cr = $0D
WHITE = $05
wht = $05
GREEN = $1E
grn = $1E
BLUE = $1F
blu = $1F
YELLOW = $9E
yel = $9E
CYAN = $9F
cyn = $9F
RIGHT = 29
right = 29
RED = 28
red = 28
PURPLE = 156
pur = 156
blk = 144
TRILEFT = 169
TRIRIGHT = 127
; Menu screen
plot_scram:
.byte clr,wht,cr,cr,right
.byte rvon," ", right, red, " ",right,pur," ",127, right
.byte GREEN," ",right,blu,127,right,right,169,cr, wht
.byte rvon,right," ",rvof," ",rvon,red," ",rvof,pur," ",rvon," ",right," "
.byte right,grn," ",right," ",blu,right," ",127,169," ",cr, wht, right,rvon
.byte " ", right, red," ",rvof," ",rvon,pur," ",127,right,grn," "
.byte right,blu," ",rvof,127,169,rvon," ",cr,wht,right
.byte " ",rvon," ",right,red," ",rvof," ",pur,rvon," ",right," ",right
.byte grn," ",right," ",right,blu," ",right,right," ",cr,wht,right,rvon
.byte " ",right,red," ",right,pur," ",right," ",right,grn," ",right," "
.byte blu,right," ",right,right," "
.byte 0
plot_rest:
.byte cr,cr,cr,rvof
.byte " ",rvon,yel," ",right," ",cr
.byte " ",rvon," ",right," ",right,right,right," ",cr
.byte " ",rvon," ",rvof," ",rvon," ",rvof," ",rvon," ",cr
.byte " ",rvon," ",right," ",cr
.byte cr,cr," ",rvon,grn,"COPYRIGHT 1983",cr,cr
.byte " ",rvon,cyn,"NALIN SHARMA"
.byte 0
.byte "Cart by e5frog "
; jmp copy_0000_2
; jmp copy_0000
take a look here:
http://one.xthost.info/nbla000/vic20/prg2cart/
they are my old conversion for first MegaCart tests that you may use for your home-made multicart or for any hacked vic-cart for BLK5....
actually on MegaCart i use prg files without modifies and use a general loader with some parameter stored into rom to move files from eproms directly to ram so no more BLK5 simulation for this work....
- e5frog
- Vic 20 Nerd
That's what I do to - copy down to RAM and execute.
What's BLK5 simulation?
sorry i intend these hacked carts:e5frog wrote:What's BLK5 simulation?
http://sleepingelephant.com/ipw-web/bul ... 9281#19281
http://sleepingelephant.com/ipw-web/bul ... 1129#21129
http://sleepingelephant.com/ipw-web/bul ... 7655#27655
- e5frog
- Vic 20 Nerd
