Ah well, not to worry. I guess as one of the guys suggested, we could always replace the graphics in the game.
Is there any hope with the SEUCK tape? Would it be possible to still send this up?
Corrupted Vic 20 game (Not seen before)
If you already tried to align and could not get better results, I may try to fix your TAP files rather than importing the tape by myself.fgasking wrote:Is there any hope with the SEUCK tape? Would it be possible to still send this up?
To correct the errors, I need to compare this game against a working SEUCK game. Can you produce a TAP file by using an emulator (just save one of the builtin games), please? Send me the loader as well.
Luigi.
Hi Luigi,
Here is a working TAP file of a SEUCK save (Axel2dat or something similiar which loads fully).
http://gtw64.retro-net.de/seuck.zip
Also inside the zip is a copy of SEUCK which will allow you to load files too from "Storage". When loading in SEUCK, it should come up with the filename and a Y/N prompt.
I hope this is all ok,
Thanks very much for this and good luck!
This is the file I ended up with after joining together the two parts:
http://www.luigidifraia.com/c64/_recove ... joined.zip
all of the blocks are there but, as I said before, there are at least 7 (obvious) read errors (some others may not show up at all). It doesn't load of course, but I can still try a reconstruction. If we end up with something that can be executed, then maybe you can judge if it's worth fixing it properly.
Luigi.
Luigi.
Hi Luigi,
That sounds really cool. I won't be sure what it is exactly until I see parts of it. If I can see a few sprites, I should be able to judge better.
I think it could be a game which I produced with an old friend many years ago across about 2 days. Must be from around 1993/94 time so it could be quite significant
All the best,
Frank
All the best,
Frank
