Lost version of Frogger? FOUND!
This is possibly an unknown version of Frogger. I bought it in 1984 from a computer store in Canberra, Australia. It came on a plain tape with no sleeve, just a plain case and a green spot sticker with "frogger" handwritten on it. I have not seen it anywhere else and a quick scan through the online archive doesn't show it.
Download it here http://gringo.strangled.net/frogger-stinky.tgz
Notes: For the unexpanded VIC. frogger is the basic loader which has a bogus load statement, but pokes a routine into RAM which loads the next part which I have named zfrogger.
I can't remember the details as I archived it many years ago, but zfrogger loads to $1000, test it with a 3k expander and load it with ,1. Sys 4096 to start it. I think I dumped it like this because of the special loader trick. Both files are exactly as they are in VIC RAM, but could use a cleanup for other things.
This is my favourite version of frogger on the VIC and IMHO the best. I'm sorry that I hadn't uploaded it previously and I would like for this to be included in Mega-Cart if possible.
- Mayhem
- High Bidder
Hi, i've tested your frogger discovered version and i think there is a very close/same game in zimmer/arma's but i don't remember the name at the moment.
You probably don't know Frogger '07 absolutely the best Vic-20 frogger conversion, it was released by Victragic, another Australian guy.
Frogger '07 is a game for any Vic+16K, full infos on this thread.
Stinky wrote:This is my favourite version of frogger on the VIC and IMHO the best.
I need to check if is possible because i need to hack it since is a multi file version, btw FYI Frogger '07 is included on Mega-Cart, to be honest is my Vic favorite game after Salmon RunI'm sorry that I hadn't uploaded it previously and I would like for this to be included in Mega-Cart if possible.
I need to investigate but i think is a game for the Vic+3K even if the start address is $1000.Mayhem wrote:I can't get the files to load properly (even after putting them in a D64)
On vice set a vic+3K
if you want to see instruction:
LOAD"FROGGER",8
RUN
to run the game:
LOAD"ZFROGGER",8,1
and after SYS4096 to start it.
Can someone explain how to start this in VICE?
There was no file extention on the unRAR'd file, so I assumed it was a .PRG and renamed it such.
Then I opened VICE and switched to 3K expansion (as the poster suggested above).
The I choose "AUTOSTART DISK/TAPE IMAGE" and it loads, but then starts automatically (no time to type the SYS command recommended) and I get a black screen that hangs.
It seems like I need to put this on a D64 image - is there a quick way to do that in VICE (i.e. create a blank D64 image, then get this PRG onto it)?
- Mayhem
- High Bidder
If you want to start it without create a D64 image using Vice on WINDOWS, this is the way:ral-clan wrote:Can someone explain how to start this in VICE?
1) Unrar the tgz file and rename the file "ZFROGGER" as ZFROGGER.PRG
2) open VICE, set the memory as VIC+3K and close VICE.
3) Double click on ZFROGGER.PRG by holding the Caps-Lock key (Run-Stop for VICE) this prevent load and autorun.
4) In Vice (Vic+3K emulated) go up with cursor keys and press "RETURN" above the row LOAD"ZFORGGER.PRG",8,1 and after type SYS4096 to start it instead of RUN.
Enjoy yourself
PS: To create D64/D71/D81 images i use Star Commander a DOS program that works in windows too, btw i've tried DirMaster and i must say that is really practical and cool
I can't exactly remember how it works but the original program did run on an unexpanded VIC. The details are hazy but the loader would start and load directly to $1000, which is why there's a problem loading from basic. This version of Frogger was a favourite in my youth. It is remeniscent of "Road Toad" on the 64.nbla000 wrote:I need to investigate but i think is a game for the Vic+3K even if the start address is $1000.Mayhem wrote:I can't get the files to load properly (even after putting them in a D64)
I still have the tape somewhere, but it's in another city. Be sure that this is the 100% version.
- Mayhem
- High Bidder
I've had a look at the program, the correct entry point is $10F0, so sys 4336 will start it correctly. There also seems to be some extraneous bytes appended to zfrogger. I'll do a cleanup and onefile when I've got some time.
Also in the archive is SNAKMAN, this ubiquitous and excellent game is complete and is a version released in Australia by "Computer Classics". It may differ slightly to the other online versions.
- Mayhem
- High Bidder
Snakman I actually have via a random purchase I made a couple of years back; if not for that I would certainly still need the file you uploaded. But as it's a one-piece and I made a TAP, it's still going in
I've uploaded the Anirog version of Frogger if you wish to check it out. I know Anirog did license games from other companies (especially Kingsoft in Germany) but I believe this is one of theirs...
http://www.mayhem64.co.uk/misc/FroggerAnirog.zip
Thanks, I did double click on the icon for FROGGERZ.PRG.nbla000 wrote:If you want to start it without create a D64 image using Vice on WINDOWS, this is the way:
Enjoy yourself
Unfortunately, VICE starts, then looks for a file:
LOAD "*",8,1
SEARCHING
?FILE NOT FOUND
READY.
I tried changing "*" to "FROGGERZ.PRG" but it cannot find that either.
I did get the game working from the D64 posted by Mayhem though.
Thanks anyway.
Yes it's pretty much the same game but there are some tiny differences. The intro is different of course, and the lady frogs are a different colour.Mayhem wrote: I've uploaded the Anirog version of Frogger if you wish to check it out. I know Anirog did license games from other companies (especially Kingsoft in Germany) but I believe this is one of theirs...
