More random questions
Okay programming wizards,
I'm looking for a simple 'random' routine in assembly that will select the numbers 0 to 255, only *once*, in a seemingly random order when the routine is called 256 times.
I had a look on The Fridge and at 6502.org, but don't even know what I'm looking for is called..
Once again, thanks in advance..
-Glen
-Glen
3^4 is 81.0000001
Do you have a spare page of RAM you can give over to this? If so, fill it with the values $00 to $ff, then spend a little time picking two random numbers of any value and swapping the numbers in those positions in your table. Do it enough and it'll appear random but not repeat the values until all 256 have gone past.
If you want a different set of randoms every time the program is run (or more often) then TMR's suggestion is the best I know of.
If you want the same "random" sequence every time, then an 8-bit Linear Feedback Shift Register is what you want.
I used the same one for both Splatform and (on the C-64) Minima and its sequels:
Two things:
1) You have to make sure that "blah" is never set to zero, or it'll get stuck endlessly outputting zeros. So, initialize blah to anything but zero.
2) The sequence will repeat after 255 calls, not 256; zero is not part of the sequence.
LFSRs were probably most famously used in early Atari 2600 games. If you ever wondered how 4k of ROM and 128 bytes of RAM allowed for the 256 "room" world of Pitfall! or the seemingly endless scrolling world in River Raid, now you (sort of) know.
random
lda blah
asl
eor blah
asl
eor blah
asl
asl
eor blah
asl
rol blah
lda blah
rts
Thanks for both responses -
I don't have 256 bytes to play with (otherwise TMR's recommendation would be perfect - I had come to similar conclusions in trying to work out how to achieve this) and it doesn't have to be a different sequence each time it is run, so I'll go with a linear feedback shift register..
-G
-G
3^4 is 81.0000001
Can't you feed the linear feedback shift register with different values to get random sequences every time you run the program?
I tried the code above, but I only get a 32 byte "random" sequence, not 255 bytes?
rng equ $fd
ldx #0
ol$: lda $a2
sta rng
il$: lda rng
asl
eor rng
asl
eor rng
asl
asl
eor rng
asl
ror rng
lda rng
sta $1e00,x
inx
bne il$
wk$: lda 197
cmp #64
beq wk$
bne ol$
Yes, you can seed it with a different non-zero value to enter the sequence at a different point. But the sequence is the same every time.carlsson wrote:Can't you feed the linear feedback shift register with different values to get random sequences every time you run the program?
Another instruction, like BRK, would make an even bigger differenceBah. Spot the typo. I used ROR instead of ROL. Interesting how one instruction can make that great difference.
I think that's the first thing I thought of too, when I was first learning assembly. I made the beginnings of a scrolling shoot-em-up on the C-64, with some sort of grass pattern repeated full screen. I was very proud of it, but then I realized how boring it looked, and that I couldn't scroll anything else on to the screen with the same trick, so I gave up on thatJeff-20 wrote:I was just wondering what the ROR and ROL commands could be used for. I had imagined they could only be useful to me for scrolling user graphics (or some other kind of visual effect) I don't know.
For Splatform, I used ROR/ROL/LSR/ASL to generate the shifted graphics to make the scrolling look smooth. In hindsight, it may have been quicker just to have shifted all the graphics myself manually; I think the code to do the shifting is longer than the data it generates! But anyway, here's a little snippet from Splatform:
;make copy of platform shifted by 1 bit for smooth scrolling
ldy #7
.loop7 lda char+plat_mid*8,y
cmp #$80
rol
sta char+plat_mid*8+8,y
dey
bpl .loop7
- Kweepa
- Occupation: Game maker
Since I didn't find anything on the internet, I just did an exhaustive search of the a and c parameters for a mod 256 Linear Congruential Generator, feeding the results into Monte Carlo Pi (PI) and Serial Correlation Coefficient (SCC) tests from "ent" (http://www.fourmilab.ch/random/).
There were a number that produced almost identical results (3.143 and 0.0004), the simplest being R = (9*R + 193)%256.
This will do exactly what Glen asked for, cycling through all 256 numbers (including 0). It's also 5 bytes smaller (13/18) and 10 cycles faster (20/30 excluding the jsr/rts) than the LFSR posted above.
The LFSR does well on the PI test (3.143) but badly on the SCC test (0.5). However, any single bit from the LFSR does well in the SCC test, whereas the less significant bits of this LCG do badly.
If for some reason you don't like the sequence of numbers generated, you could try any of these multipliers (a) and constants (c).
This is probably more info than you need, but you never know - this is the info I was looking for.
random
lda blah
asl
asl
asl
clc
adc blah
clc ; added this after johncl noticed the code was wrong!
adc #193
sta blah
rts
a = 13 c = 211
a = 29 c = 143
a = 33 c = 169
a = 41 c = 123
a = 65 c = 73
a = 69 c = 33
a = 69 c = 35
a = 81 c = 119
a = 93 c = 73
a = 101 c = 181
a = 109 c = 211
a = 113 c = 247
a = 117 c = 37
a = 145 c = 25
a = 149 c = 133
a = 153 c = 7
a = 169 c = 71
a = 173 c = 61
a = 177 c = 187
a = 185 c = 177
a = 201 c = 129
a = 209 c = 123
a = 229 c = 65
a = 245 c = 35
Cool, I was unaware of these. I'll try one next time I've got a project where I would have used the old trusty LFSR and let you all know how it goes. And no, that's exactly how much info I'd need if I was to use itKweepa wrote:Since I didn't find anything on the internet, I just did an exhaustive search of the a and c parameters for a mod 256 Linear Congruential Generator...
...This is probably more info than you need, but you never know - this is the info I was looking for.
More reading here (don't know why I hadn't thought to look before):
http://en.wikipedia.org/wiki/Linear_con ... _generator
http://en.wikipedia.org/wiki/Pseudorand ... _generator
Re:
This code above does not work. Sat for an hour last night and wondered if I had done something wrong when I integrated it, only to test the algorithm on its own and found out it gives me these these values: $c1, $8a, $9b, $35, $9e - and then onto these - $50, $91, $db, $75, $df, $99, $23, $fc, $9e, $50... endless loop...Kweepa wrote:Since I didn't find anything on the internet, I just did an exhaustive search of the a and c parameters for a mod 256 Linear Congruential Generator, feeding the results into Monte Carlo Pi (PI) and Serial Correlation Coefficient (SCC) tests from "ent" (http://www.fourmilab.ch/random/).
There were a number that produced almost identical results (3.143 and 0.0004), the simplest being R = (9*R + 193)%256.This will do exactly what Glen asked for, cycling through all 256 numbers (including 0). It's also 5 bytes smaller (13/18) and 10 cycles faster (20/30 excluding the jsr/rts) than the LFSR posted above.Code: Select all
random lda blah asl asl asl clc adc blah adc #193 sta blah rts
Here is the one I have used before (but are open to alternatives). I believe I found this on codebase64:
// Simple RND function using ASL and EOR
seed: .byte 0
rnd: {
lda seed
beq doEor
clc
asl
beq noEor // if the input was $80, skip the EOR
bcc noEor
doEor: eor #$1d
noEor: sta seed
rts
- Kweepa
Re: More random questions
Oh jeez, you're right. Here's the corrected code:
I tested its output against the C version I wrote before when testing the randomness, and it worked this time.
Sorry about that!
(I'll also edit the code up above so there isn't a wrong version in the thread.)
random
lda blah
asl
asl
asl
clc
adc blah
clc ; note this second clc.
adc #193
sta blah
rts
Sorry about that!
