Random number generation on a VIC
Hi,
apologies if this has been raised before...
I'm looking for a quick way to fill the screen with random characters between a certain limit.. say 0-7..
I find I can create 'randomness' if I slow things down and generate a number based on the Raster beam location, but surely there's a quicker and easier way? What is the internal random function RND based on?
If someone can help out, I'd be mighty obliged
-Glen
-Glen
3^4 is 81.0000001
Re: Random number generation on a VIC
RND(0) uses TI, RND(1) is based on a linear-congruential generator (seeded with RND(-x)). However, Commodore tried to "improve" upon that, by swapping some bytes, and thus broke the RND() function. It already loops after ~60000 calls, even though it would loop only after 4 billion numbers if it were not broken.Victragic wrote:What is the internal random function RND based on?
In ML, you might try a linear-feedback-shift generator, something like:I'm looking for a quick way to fill the screen with random characters between a certain limit.. say 0-7.. [...] generate a number based on the Raster beam location, but surely there's a quicker and easier way?
LSR $FA
ROR $FB
BCC skip
LDA $FA
EOR #$AA ; most significant bit *must* be set
STA $FA
LDA $FB
EOR #$2B ; least significant bit should be set
STA $FB
.skip
The Fridge at Stephen L. Judd's ffd2.com site has some good stuff, like this random routine. And this.
Bacon
Take a look to this old thread too.
I've used Carlsson/Nippur72 solutions for my works, the last was a random game selection inside the Mega-Cart Menu.
This thread's a bit old, but i thought i'd add a comment from what i've rediscovered disassembling River Rescue (which i wrote 25 years ago).
If there's no human intervention, random number generation is fairly tricky, but once human input comes into it, it becomes quite easy, i think.
After a bit of experimenting (in the 80s), the way i implemented a random number generator was with three counters - one incremented every time the NMI handler was called, one incremented by the IRQ handler, and one which was incremented every time round the main control loop.
The random number generator takes the raster value and XORs it with each of those counters, one after the other. The result's returned as the "random" number.
That random number generator is used in the intro routine and in demo mode - but it's certainly not very random in the intro or the first run of the demo mode. In fact, if it's allowed to run into the demo mode after start up, it repeats the same pattern each time. I'm using Vice, so the raster scan timing's probably rock solid, but the raster timing of the Vic hardware might be a different matter altogether. Athough i guess the timing of everything would fluctuate together. However, i can't remember it being so predictable in the pre-play state when i wrote it.
As soon as you hit a key though, it starts to become a lot more random. That's because a fraction of a second difference in the time you hit the start key, or move the joystick, press the fire button, etc, makes a significant difference to the generated random number.
It's pretty random, i think, but it must respond to the way it's played - in some intangible way - i reckon!
- Kweepa
- Occupation: Game maker
I found a bug in the LCG in rand1.s (by comparing with the output from a C version): the carry bit should be cleared before adding $3611. So the code should be:Bacon wrote:The Fridge at Stephen L. Judd's ffd2.com site has some good stuff, like this random routine.
GETRAND
LDA RANDOM+1
STA TEMP1
LDA RANDOM
ASL
ROL TEMP1
ASL
ROL TEMP1
CLC
ADC RANDOM
PHA
LDA TEMP1
ADC RANDOM+1
STA RANDOM+1
PLA
CLC ; added this instruction - kweepa
ADC #$11
STA RANDOM
LDA RANDOM+1
ADC #$36
STA RANDOM+1
RTS
[EDIT]
I ran some tests on the old code vs. the new code using "ent" to ensure correct behaviour. For the statistical tests, I used the top 8 bits.
TEST NEW OLD
Entropy 8.00 6.35 bits per byte - good random # generator should be 8
ChiSquare Dist 0.00 2.36 value - good random # generator should be 0
ChiSquare rand 50.00 0.96 % - good random # generator should be 50
Mean 127.50 124.78 good random # generator should be 127.5
Monte Carlo pi 3.13 3.12 good random # generator will approach 3.14 slowly
Serial correlation 0.00 -0.03 good random # generator will be 0
