Biathlon
Biathlon
As the first snow seems to be approaching Italy, I looked for some VIC winter games, and I found this review in Retrogaming Times Monthly #21.
So, I recalled the graphically excellent Biathlon found in a German disk collection. No instructions though. Anyone has an idea about the game controls?
Here's a screenshot:
Thank you.
Thank you.
I've checked Biathlon few month ago to add it on Mega-Cart but after testing all keys and joy without results i've discarded it.
May it works using paddles ?!?!
In effect i've checked it using Vice not real hardware.
btw really impressive graphic !!!
If I'm not mistaken, at least the German gentleman from whose page we found it is a member on this forum. He may not write very much.
Since you two have posted slightly different screenshots, at least Orion must've managed to move the skier a little bit. I have vague memories actually finding out how to play the game, which graphically is copied from Epyx' Winter Games, indeed in a very nice fashion.
Ah, this is written in BASIC and a quick scan of the code, I saw that the "Z" key and the "X" key are used one after the other. For each ZX key press you get 2 added to your speed. When you get to the shooting part, use the back arrow key (ESC ). You run thru the 4 screens 3 times and then you get scored. Nice graphics. If you warp Vice, you can see all the screens. The only reason the 2 screen shots above are different is because the skier will go forward after so long on its own. It's hardly playable for me. Even rapid repeats of ZX won't get you going very fast.
Rob
Re: Biathlon
Just trying out this game, it is quite pretty and has the nice rendition of chariots of fire at the start, but as people have said it's pretty unplayable I've managed to get up to 20 speed then it drops down for no reason and I can't get it back up.
There's probably quite a few games that could do wtih a bit of revision.
