My C64 mod
stonan
My C64 mod
Post by stonan »
Here is my C64 mod.
- Integrated 7 inch TFT monitor
- SID2SID
- XLR and RCA Audio jacks
- RCA video out connection
- RCA video in connection (for an additional video input to the monitor)
- Spraypainted black
- White C64C keyboard
http://picasaweb.google.com/anders.stonan/Commodore
Centallica
Pinballer
Post by Centallica »
Sweeeeet! :shock:
The pictures on the website does it more justice!
When are you taking orders for them? :P
I think everyone saw this picture first in the event report. It's very nice! I may steal that idea. The VIC character size would probably make for an excellent image.
I was wondering what this was on the show report. Nice to have the explanation. Where did you get the little LCD TV or monitor (and if a monitor does it accept a PAL signal)?
stonan
Post by stonan »
ral-clan wrote:Where did you get the little LCD TV or monitor (and if a monitor does it accept a PAL signal)?
The monitor is a standard monitor for use in cars. This one got a higher resolution so the picture is real good. The price is around 180 US$. I think it takes both PAL and NTSC.
stonan
Post by stonan »
Centallica wrote:When are you taking orders for them? :P
This is my first mod. There's is more to come further on I guess :wink:
gklinger
Vic 20 Elite
Post by gklinger »
stonan wrote:This is my first mod. There's is more to come further on I guess :wink:
You do really nice work. You're going to have quite a time topping that effort. I guess that's half the fun.
It's a really good idea to make a more portable system, but how is the monitor powered? By a separate power supply?
stonan
Post by stonan »
Jeff-20 wrote:but how is the monitor powered? By a separate power supply?
Yes! The TFT uses 12 volts and the connection for the 12 volts is on the back, near the normal power input.
It might work with a voltage regulator to boost up the voltage to 12 volts but I guess I need to use a more heavy duty power supply for the C64 like the PSU that comes with the REU for example.
Boray
Musical Smurf
Post by Boray »
Wow!!! That is so cool!
What are the XLR outputs for? Do you mean you have balanced audio out?
Jag ser förresten att du har köpt en tejprulle på Biltema! ;)
stonan
Post by stonan »
The XLR outputs is not balanced, they are connected to the same audio outputs as the rca's, that way you don't need any adapters if you going to use XLR-cables. (To Boray, the spraypaint is also from Biltema)
Boray
Musical Smurf
Post by Boray »
stonan wrote:(To Boray, the spraypaint is also from Biltema)
Ah! Just like my blue vic! :D
nbla000
Salmon Run
Post by nbla000 »
Wow a very nice mod Stonan!!!
My dream is an Amiga 1200 with a TFT monitor.
I've a broken laptop with a working monitor but ...
From what I understand, it's pretty hard to hook a salvaged laptop LCD to an analogue signal. You need to know the signals the particular LCD expects, know the pinouts/ins and create an interface that will convert the signals (D/A?) Even to send a regular VGA video signal to a salvaged LCD monitor would be pretty difficult to do, I imagine.
I have two old salvaged LCD panels from 486 laptops. I wish I could put them to use, too... :cry:
I'm sure if Stonan had made 10 of those units and sold them for $600+ each, all of them would be sold by now.
