Summer 2007 programming challenge: 358 bytes of Basic V2!
I felt for a little programming challenge. 3583 BYTES FREE? That's too much. 1/10 of that sounds like a nice challenge I think. Write something (anything really) in just 358 bytes of basic code. (The .prg file can be at most 360 bytes). The program should run on a vic-20. Memory expansions and disk drives are allowed but not basic extensions.
If you have no web space, you can mail it to me at
Have fun!
Have fun!
358 bytes of anything. That's the idea.
Boing
Boing
Download:
http://user.tninet.se/~pug510w/datormuseum/boing.zip
Programmed on a real PAL vic-20. Runs in both unexpanded and expanded mode.
The NTSC version is tested in VICE only.
PAL version:
NTSC version
Download:
PAL version:
0 X=36864:Y=X+1:V=X+14:L=V-4:A=8:B=10:Q=1:W=1:POKEV+1,8
1 PRINT"{CLR}{GRN}BY ANDERS PERSSON 2007{DOWN} 358 BYTES CHALLENGE"
2 FORT=1TO900:POKEV,9:POKEV,0:NEXT
3 PRINT"{CLR} {C=-@}{C=-P}{C=-@} {RVS ON}{SH-POUND} {C=-*} BORAY {RVS OFF}{C=-*}{RVS ON} {RVS OFF}{SH-POUND} {C=-T}{C=-Y}{C=-T}":POKEY+1,(PEEK(Y+1)AND128)+7
6 A=A+Q:IFA<8ORA>47THENQ=-Q:POKEV,7:POKEL,180
7 B=B+W*(B/10):IFB>130THENW=-W:H=15:S=130
8 POKEL,S:IFB<9THENB=9:W=-W
10 POKEV,H:IFH>0THENH=H-1:S=S+1
11 POKEY,B:POKEX,A:GOTO6
NTSC version
6 A=A+Q:IFA<4ORA>37THENQ=-Q:POKEV,7:POKEL,180
7 B=B+W*(B/10):IFB>100THENW=-W:H=15:S=130
8 POKEL,S:IFB<8THENB=8:W=-W
C64
The c64 is now also included in the challenge.
( http://folkvagn.commodore64.org/phpbb/v ... hp?p=14987 )
The basic is exactly the same, so why not! Make your choice, vic-20 or 64. Just as long as you only use Basic V2 and the prg file not is bigger than 360 bytes.
If you want to check if your program is within the limit:
On a vic-20 write
CLR:PRINT FRE(0)
...and you will get the number of free bytes. On an unexpanded vic-20, this value can't be lower than 3225.
On a c64:
CLR:PRINT FRE(0)-(FRE(0)<0)*65536
...This value can't be lower than 38553.
On a vic-20 write
CLR:PRINT FRE(0)
On a c64:
My second 358 byte program:
PrgInfo
Download:
http://user.tninet.se/~pug510w/datormuseum/prginfo.zip
That's right, it's a 358 byte version of this program:
http://user.tninet.se/~pug510w/datormuseum/prginfo.html
Should run on any Commodore 8-bit computer.
PrgInfo
Download:
3 INPUT"FILE";F$:OPEN1,8,0,F$:GET#1,A$,B$:IFST<>0THENPRINT"ERROR":CLOSE1:END
4 IFA$<>""THENA=ASC(A$)
6 CLOSE1:A=A+ASC(B$)*256:PRINT"{DOWN}ADDRESS"A"{DOWN}"
9 READB,B$:IFB=0THENPRINT"???":END
12 IFA<>BTHEN9
18 PRINTB$:DATA4097,VIC20 UNEXP /PLUS4,1025,VIC+3K,4609,EXPANDED VIC
21 DATA2049,C64,7169,C128,40960,VIC BL5,24576,VIC BL3,16384,VIC BL2
24 DATA8192,VIC BL1,45056,VIC BL5,28672,VIC BL3,20480,VIC BL2,12288,VIC BL1,0,0
Re: Summer 2007 programming challenge: 358 bytes of Basic V2
Boray wrote:I felt for a little programming challenge. 3583 BYTES FREE? That's too much. 1/10 of that sounds like a nice challenge I think.
cool - kinda like the 256 byte demo scene for the pc - but specially adapted for the vic (or c64). I'm in - just gotta come up with a good idea now
BASIC auto-tokenizer for SEQ files
My entry. Around 150-160 bytes (depending on the filename used):
this is (more or less) the inverse to:
only that the appended 'READY.' will disturb the program a little bit. Just type in a final 'GOTO63997' to cleanly end the process.
Edit: corrected a small typo
63996 POKE812,238:OPEN2,8,2,"FILE,S,R"
63997 PRINT"{CLR}";:IFST<>0THENPOKE812,239:CLOSE2:END
63998 GET#2,A$:PRINTA$;:IFA$<>CHR$(13)THEN63998
63999 PRINT"GOTO63997":POKE631,19:POKE632,13:POKE633,13:POKE198,3
OPEN2,8,2,"FILE,S,W":CMD2:LIST
PRINT#2:CLOSE2
Mike, I tried your program in VICE and nothing happens?
You mean I should input something?
Yes. Preferably you should make available a SEQ file named "FILE", that contains a PETSCII program listing. Or any other name, if you alter the OPEN command in line 63996.
As an example, construct the file "FILE" as follows:
1. RUN this program. After this, there will be the file "FILE" on disc, SEQ type.
2. Enter NEW to prepare for the next program.
3. Then type in my 4-liner, enter RUN again. The SEQ file will be read in, and tokenized. Afterwards, you may delete the lines 63996-63999.
4. Enter RUN a third time to start Example 1 of the User's guide.
(methinks there are no dumb questions, only dumb answers...)
Hope that helps,
10 OPEN2,8,2,"FILE,S,W"
15 PRINT#2,"1 PRINT"+CHR$(34)+"VC20"+CHR$(34)+";"
20 PRINT#2,"2 GOTO 1"
25 CLOSE2
Hope that helps,
Aha! ok... thanks...
Reminds me of my "datamaker" program: http://user.tninet.se/~pug510w/datormus ... maker.html
