Duane Later Honorary Remix Compo?
I just got an idea:
Would anyone be interested in a game remix compo, where we all take one of the listings in the VIC-20 manual (Tank-vs-Ufo, Killer Comet or Rocket Command) and then, within 3.5K memory add as much as we want to the game? Think custom characters, improved gameplay, scenarios, high score lists and so on.
We would have to choose which of these three programs to work from, and that the final listing should be possible to type in as a Basic program. It means custom characters, ML routines etc would have to come as data statements. Maybe we want to limit ourselves to 2K listing to not get too long programs.
We had the 20 line compo/showroom before, but it is about time for something new. Almost everyone of us can dabble in Basic to some degree, and preferrably people would be allowed to team up if desired.
I'm interested too. carlsson, I'm kind of lazy, so could you provide links to the exact versions of the games you're talking about?
If someone wanted to team up, I could possibly provide some ML support routines. Especially if someone had things working in BASIC and just needed a speed boost.
I'd rather not have any limit but the natural 3.5k limit (like, no listing size limit), since data statement really take a lot of space for the code they produce.
Killer Comet from the VIC-20 manual:
http://www.cbm.sfks.se/files/killercomet.prg
As you can see, a lot of expressions can be optimized; i.e. all those 9*16^3 can be replaced by 36864 or a variable. Of course there is much more to do than optimize the code as it lies.
0 REM"{6 DEL}" KILLER COMET BY DUANE LATER
1 C=7680+22*6:DIMB(12):LL=C:POKE9*16^3+15,8
2 PRINT"{YEL}{CLR}*** KILLER COMET ***":T=0
3 PRINT" HIT ANY KEY"
8 POKE8179,160:
9 FORA=38444TO38400+505:POKEA,1:NEXT
10 :
20 FORA=1 TO 12:B(A)=160:NEXT
21 IFW=0THEN25
22 POKE9*16^3+14,U:U=U-2:IFU<=0THENW=0:POKE9*16^3+13,0
25 F=1:REM ERA METEOR
26 FORE=0TO44STEP22
27 FORD=C+ETOC+3+E:POKED,32 :F=F+1:NEXT:NEXT
28 C=C+1
29 F=1:REM DRAW METEOR
30 POKE8179,160:FORE=0TO44STEP22
35 FORD=C+ETOC+3+E:POKED,B(F):F=F+1:NEXT:NEXT
36 IFPEEK(8178)=160THENPRINT"{CLR}{4 DOWN}MOON BASE DESTROYED !":GOTO500
40 GETA$:IFA$<>""ANDG=0THENG=1:S=7680+15+22*21
50 IFG=0THEN80
55 POKES,32:S=S-22
60 IFS<7746THENG=0:GOTO21
70 IFPEEK(S)=160THENPOKES,32:G=0:T=T+1:W=1:POKE9*16^3+13,128+000:U=15:GOTO80
71 IFPEEK(S-1)=160THENG=0:POKES-1,32:T=T+1:W=1:POKE9*16^3+13,128+000:U=15:GOTO80
75 POKES,81
80 F=1:REM CHECK MET
81 IFT=12THENPRINT"{CLR}{3 DOWN}***METEOR DESTROYED***":FORRR=1TO2500:NEXT:LL=LL+44:C=LL:GOTO2
82 FORE=0TO44STEP22
84 FORD=C+ETOC+3+E:IFPEEK(D)=32THENB(F)=32
86 F=F+1:NEXT:NEXT
90 GOTO21
500 POKE9*16^3+13,128+5
505 POKE9*16^3+14,5:FORRR=1TO300:NEXT
510 FORA=15TO0STEP-1
511 POKE9*16^3+14,A
520 FORRR=1TO500:NEXT
530 NEXT
540 FORRR=1TO2000:NEXT:RUN
Yeah! What was Duane doing? It seems like the program is intentionaly obfuscated to discourage young programmers from understanding it! When I was a kid, I felt like he was kind of a wise-ass or even a jerk for doing that.carlsson wrote:9*16^3 can be replaced by 36864 or a variable.
Look at line 10. Can anyone give me any reason why a programmer would throw in a line like line 10??? Yet, at the same time, there are REM statements delineating sections of the program. Is he being playful or am I just missing something?
I'm pretty sure he was trying to make it seem like less of a magic number he pulled out of the air by showing how he converted a hex address to decimal.Jeff-20 wrote:Yeah! What was Duane doing? It seems like the program is intentionaly obfuscated to discourage young programmers from understanding it! When I was a kid, I felt like he was kind of a wise-ass or even a jerk for doing that.carlsson wrote:9*16^3 can be replaced by 36864 or a variable.
The address is $9000, so that is 9*$1000. $1000 can be expressed as $10^3 (showing that the $10^1 is shifted two places over). So $10^3 becomes 16^3.
Yeah, I don't think he was very successful at making things clearer for the kids out there, but I do think his intentions were good. Or perhaps that's just how he thought things through in his own mind.
Line 10 is a pretty common way of leaving a blank line in C= BASIC, just for formatting. Though it's placement is a little weird, I guess it's to seperate the title screen code from the rest of the game.Look at line 10. Can anyone give me any reason why a programmer would throw in a line like line 10??? Yet, at the same time, there are REM statements delineating sections of the program. Is he being playful or am I just missing something?
Both REM and : use the same amount of memory in a program, so there's no advantage there to either.Jeff-20 wrote:It seems like a REM statement would suffice.
I do find the : slightly more visually appealing (I've used it for years instead of an empty REM line), but I just did some speed tests, and the REM is marginally faster, so I guess that's the better choice.
I once typed in all three programs, with all excess spaces and colons faithfully included. I.e. as original as possible.carlsson wrote:I was lazy and downloaded as pure versions as possible from Zimmers (there are a few hacks there to ignore).
Jeff, if you could host them on Denial, I'd send the *.prg files to you in an e-mail.
It is also possible that he developed different versions, and finally got one short enough to publish.
I believe 38400+505, 7680+15+22*21, 128+000 and 128+5 also are due to being pedagogic. In a finished game, you would calculate those instead of using fixed formulas. It surprises me a bit that he didn't write 0*16+0+8 for the background/border combo.
How do we go on, posting .prg files of everyone's progress so far, or that you only submit when you have what you consider a final version, modulo bugs you didn't find? I already have a number of ideas and twists to possibly implement.
POKE 1 - 2 + 3 - 4 + 5 . . .
Killer Comet is a very boring program now that I have reviewed it. This could be a real challenge.
