Hi, we had a discussion here a few months ago about VIC-20s being yellowed by UV light. However, I am pretty sure the sun is doing the opposite to my VIC.
I have my VIC in an upstairs porch with large windows all around, so it gets a fair amount of light. It seems pretty white to me after several years there.
Also, there is a tiny part of the VIC's case that is hidden under a "lip" made by a window sill. When I pulled the VIC-20 out I could swear that this part of the casing is slightly more yellow than the rest of the VIC. In fact, the very subtle yellowing starts on a defined line that would be exactly where the sill is casting a shadow.
The brown keys on my VIC do not seem to be affected at all.
The other thing that has me wondering about bleaching, is that we have these very old plastic shades on all the windows. They are made to look like bamboo/rattan blinds, but are actually made of a plastic "drinking straw like" material.
Each blind is slightly larger than the window. Where the sun came through and hit these blinds, there is a VERY obvious lighter square (the colour was bleached?) whereas the parts of the blind that went beyond the window's borders and were in shade are very yellowed and darker.
If I had a broken VIC with a smashed case I would put the plastic shell outside this summer with half of it covered and the other exposed to the sun. Anyone want to try this experiment and post results?
I strongly suspect the sun is bleaching my VIC-20.
I think really old machines stands the sun better than newer ones... Is your vic-20 the old or new model?
My 1982 vic-20 has not been yellowed at all, while the datasette that came with it has been yellowed.
Interesting idea. Maybe I should put a broken VIC on my balcony in the summer and cover half of it with a newspaper or something similar. However the plastic may be so old that sun bleaching or yellowing doesn't "take" any more?
One could also put on sunshield and see if it protects the plastic in any way, or perhaps creates a reaction, scorching the plastic.
My VIC is an early model 2-prong with the brass sticker, made in Canada. But not early enough to have PET keys. It has keys similar to the first C64s (narrow letters). Anyway, if it is true that my VIC has been bleached by the sun then it is good news for some of us.
I have one VIC in my "spares" collection that is extremely yellow. It is a later model with the "rainbow" sticker....but I think it is still a 2-prong model.
If anyone does a test this summer, they could use duct tape and a couple layers of garbage bags to cover half the shell really well, then stick it in their garden or something!
Whoah, that is wierd. I wonder if some of the keys have been replaced or were just made from a different batch of plastic in the factory.
As for the big chunk out of the side. A few months ago I received an AtariSoft BattleZone cartridge for the VIC. Unfortunately it has a MS. PACMAN circuit board in it (mis-labelled). I decided to open it up to see what was going on. Even though I was very gentle in flexing the cartridge to open it up, it totally shattered and fell apart in my hands. The plastic was extremely brittle from age....there was no flex left in it at all.
I would never turn down a cheap Amiga even if it were yellowed, though! I like a nice white system, but yellowing doesn't bother me enough to reject it.
That reminds me of when my A500 started to yellow after having owned it for around 5 years. I thought it was just dirty, so I disassembled it and gave the case a bath. I scrubbed it with a scotch brite pad; to no avail. While it was certainly much cleaner when I reassembled it, I was dismayed at the yellowed look.
That's the nice thing about the Commodore 64; because of all the brown used in its colour, the yellowing isn't noticeable.
