Datasette problems
Datasette problems
Okay, I finally scored a Datasette. It's a piece of junk, with a door that's broken and very difficult to close, but it does work. I tested it on my C-64. Connected to my Vic, it's a different story. When I type in "Load," I press play, the computer recognizes the "Play" button is pressed, but the cassette motor does not turn. When "Saving" a program, once again it recognizes that the record button is pressed, but again, no motor activity. Cannot fast forward or rewind. I now find myself asking those of you who know better; what is wrong? I'm suspecting the Vic isn't providing power to the datasette, but I've cleaned the contacts on the edge connector. Any ideas?
Re: Datasette problems
If it works fine on a 64 then refuses to spin on a VIC, then I confirm to you that the VIC doesn't provide the 9Vdc required to get the dc motor to spin.DigitalQuirk wrote:Okay, I finally scored a Datasette. It's a piece of junk, with a door that's broken and very difficult to close, but it does work. I tested it on my C-64. Connected to my Vic, it's a different story. When I type in "Load," I press play, the computer recognizes the "Play" button is pressed, but the cassette motor does not turn. When "Saving" a program, once again it recognizes that the record button is pressed, but again, no motor activity. Cannot fast forward or rewind. I now find myself asking those of you who know better; what is wrong? I'm suspecting the Vic isn't providing power to the datasette, but I've cleaned the contacts on the edge connector. Any ideas?
What type of VIC do you have ?
If it's the new vic-20 model, then it could be the fuse inside of the vic...
Good call on the fuse, Boray. I checked it, and while the fuse is good, it doesn't appear to be getting any voltage. I decided to check the pins on the power supply with my volt meter, but cannot find a pinout diagram for the Vic 20 power supply anywhere! It's the 9 pin DIN plug; I'm going to keep looking, but if anyone can post the pinout diagram for this, I'd appreciate it.
After doing more research in these forums, I decided to try my Commodore 64 power supply in my Vic. Lo and behold, the Datasette drive now works! It appears to be a problem with my Vic power supply.
I'm happy to say that I finally feel my system is complete; though it'd be nice to have a datasette drive with a door that didn't put up a fight and threaten to break further every time I close it. I'd still like to see a Vic 20 pinout diagram so I can determine which pin is faulty and possibly repair it if it's just a bad connection.
Thanks again, Boray. Your suggestion put me on the right track to resolving this problem. Today is a good day.
http://personalpages.tds.net/~rcarlsen/cbm/pinouts.txt
(It's the same for the c64 and the "new" vic-20 as you have found out)... Btw, isn't there a fuse in the power supply as well? But I think that one is for the whole power supply...?
Play button wont stay down
I am sure this is a common problem with the datassette.
The play button just will not stay down when I press it. I need to hold it down for the entire duration of the loading or saving. Clearly there is some kind of mechanical problem with some latch, inside the datassette, but I am reluctant to open it up until I get some advice first.
Paul Lambert
Berlin
Federal Republic of Germany
Paul Lambert
Berlin
