I still have about 60 adapters for sale that allow you to plug 28 pin EPROMs into a 24 pin ROM socket such as those in a VIC20 or C64.
See thread in Hardware & Tech.
Thank you
28-24 pin adapter
- Schema
- factor
The perfect companion to these boards is here:
http://www.digikey.com and search for 350-10-164-00-006000
64 pins you can breakaway, 2 of these will do 5 boards (each boards require 24 pins)
- Schema
- factor
A much cheaper equivalent of the digikey pin header can be found here:
http://cgi.ebay.ca/single-row-round-100 ... dZViewItem
You can always use the excess female connectors for DIP sockets replacements.
