Wanted: Working Vic-20
Vic 20 Item Exchange
Goldenboy
Post by Goldenboy »
I'm looking for a working vic-20, it doesn't need any games, but i'll take them too if you have them. I want this for a gift for my father, so I would like for him to be able to open it up, plug it in, and start playing. Thanks in advance. Andy
Jaicen
Post by Jaicen »
It usually helps if you tell us where you're located, as there are a lot of nationalities on this board!
Goldenboy
Post by Goldenboy »
Sorry, I'm in New York State
I have an NTSC VIC20 (later revision) here to liquidate with power supply and modulator.
asking 15$ plus shipping.
Tested and working just fine.
Goldenboy
Post by Goldenboy »
Whats the difference between the PAL and the NTSC? Is one better than the other?
Schema
factor
Post by Schema »
NTSC is the North American version.
PAL is the European version.
You won't be able to use the PAL version unless you have a PAL television set or monitor.
