Sometimes for big basic programs i will to crunch them using Pucrunch.
So this is my work:
LOAD"BASICPRG1",8
SAVE"BASICPRG2",8,1 (so Pucrunch know the exact load Address)
using Star Commander i copy the BASICPRG2 to Pucrunch Folder
command on a DOS box:
pucrunch BASICPRG2.PRG BASICPRG3.PRG -c20 -x0xc871
$c871 (SYS51313) Perform [RUN] but don't work
?UNDEF'D STATEMENT
ERROR
but if you type RUN + [RETURN] again the program start
so you must type RUN 2 times to start the crunched version
there is a SYS that do a RUN command or which execution address is necessary for basic unexpanded/3k/8k+ programs?
How to crunch basic programs
perform RUN from ML
You need to perform the following calls:
See here.
If you have a fixed start of the BASIC program, you can omit the first JSR. Then you can embed this ML code (sans re-link) into your BASIC program as follows (I assume there's no expansion) :
and specify 0x1006 as starting address.
JSR $C533 ;re-link BASIC program
JSR $C659 ;reset TXTPTR
JMP $C7AE ;handle next BASIC statement
0 REMZZZZZZ
POKE4102,32:POKE4103,89:POKE4104,198
POKE4105,76:POKE4106,174:POKE4107,199
