Hi, there is a way to speed-up a 1541/1541-II/1581 drive using a Vic-20 like the C64 does with a program or a cartridge?
I remember a routine that you must send to the drive so it works fast unless you switch off or reset it.
I've read on JiffyDos for Vic-20 and Drives replacements but i don't like to modify hardware, i use Zap loader or Action replay MK 6 for the C64, there are similar things for the Vic-20?.
how to speed-up a Disk drive using a Vic-20
- Schema
- factor
Yes, you can send "UI-" to a 1541 to get a slight increase in speed when using it with a VIC20.
There was a Turbo Load program for the VIC20 in an old issue of Compute's Gazette - I can't remember which one, unfortunately.
I've tested this 1541 only fastloader for vic-20 using 3 or more kb expansion, but doesn't work properly on vice with true drive emulation, i will test it on a real Vic-20 next Week-End.
Looking for a Vic-20 Fastloader around the web i've discovered this link:
http://www.cs.tut.fi/~albert/Pu-239/vimm/
Where there is a very impressive Vic-20 demo Copyright © 2000 Pasi Ojala, Anders Carlsson.
Carlsson?!?! are you?
Looking the notes of the first demo it says:
This starting part also detects the video system and installs the first music and the 154x/157x/1581 fastloader, which is based on Marko Mäkelä's fastloader.
In the sources there is an assembler file "loader.asm", few row code:
very interesting true?
There is any assembler coder that may use these sources to made a very first 154x/157x/1581 fastloader for the Vic-20?
HERE there are sources of the unexpanded version loader too!!!.
; FOR 1581
;acsbf8 = $03 ; job for buffer 1 (not used directly)
trkbf8 = $0d ; track for job 1
sctbf8 = $0e ; sector for job 1
;ciapa = $4000 ; (not used directly)
ciapb = $4001
ledon = $cbcc ; activity led on: $cbcc, off: $cbc3
ledoff = $cbc3 ; or using the job queue: on $94 / off $96
; FOR 1540/41/70/71
acsbf = $01 ; access to buffer 1
trkbf = $08 ; track of buffer 1
sctbf = $09 ; sector of buffer 1
iddrv0 = $12 ; id of drive 0
id = $16 ; id
via1pb = $1800
via2pb = $1c00
; For both 154x/7x and 1581
buf = $0400 ; sector buffer (for job 1)
datbf = $14 ; databuffer - temporary (on 1581 sector for job 4)
drive cld
lda $ff54 ; Execute Job -routine entry in the jump table
cmp #$4c ; jmp abs - probably exists
beq drive1581
cmp #$6c ; jmp (abs) - probably exists
beq drive1581
jmp drive1571
name ds.b 8
