Hi.
I've tried to crunch some cartridge image with Pucrunch using this command:
PUCRUNCH -C20 ImageA0.prg ImageCR.prg
but pucrunch says:
"Original file exceeds 0x8000 (0xbfff), not a valid VIC20 file!
Actually the cartridge image is of 8194 bytes.
I've tested with the -d option (data), Pucrunch works but says:
"Runnable on VIC20 with 3k+8k (or 3k+16k, or 3k+24k) expansion memory
In any case doesn't work on Vic.
What does do this Pucrunch option?
a avoid video matrix (for VIC20)
How to crunch cartridge images
Why would you crunch a cartridge image? What Pucrunch means is that the program is located at an address higher than 32768 ($8000). You may transfer the cartridge image to e.g. $2000 and write a small routine to relocate it back to $A000:
Then Pucrunch will accept the whole kaboodle.
The -a option makes Pucrunch avoid the video matrix ($1E00-1FFF) on unexpanded VIC-20. Usually it would use it for temporary storage, so you get a bit of garbage on screen while uncrunching. If you prevent it from using it, some unexpanded 4K programs may be impossible to crunch.
ldx #$20
stx $fc
lda #$a0
sta $fe
ldy #$00
sty $fb
sty $fd
loop: lda ($fb),y
sta ($fd),y
iny
bne loop
inc $fc
inc $fe
dex
bne loop
jmp $fd22 ; or whatever startup routine
i want to fast load images from floppies and add more images to a single diskcarlsson wrote: Why would you crunch a cartridge image?
My Work:
On vice (Vic memory blocks 1,2,3,5)
LOAD "IMAGEA0",8,1 (8194 bytes)
in the Monitor
MOVE $A000 $BFFF $2000 (8192 bytes ?!?)
SAVE "IMAGE20" 8 $2000 $3FFF
now with Pucrunch:
pucrunch IMAGE20.prg IMAGE20C.prg -c20 -x$2000
on vice (Vic memory blocks 1,2,3,5) again
LOAD"IMAGE20C",8,1
RUN
now in $2000 i've the cartridge to move in $A000
LOAD"20TOA0",8,1 (see code below)
SYS5120
the routine works and soft-reset the vic but the game doesn't start.
in the monitor on $a000 there isn't the same code of $2000
so manually MOVE $2000 $3FFF $A000
and after
SYS64802
and now works.
what's wrong in my routine?
1400 A2 20 LDX #$20
1402 86 FC STX $FC
1404 A9 A0 LDA #$A0
1406 85 FE STA $FE
1408 A0 00 LDY #$00
140a 84 FB STY $FB
140c 84 FD STY $FD
140e B1 FB LDA ($FB),Y
1410 91 FD STA ($FD),Y
1412 C8 INY
1413 D0 F9 BNE $140E
1415 E6 FC INC $FC
1417 E6 F6 INC $F6
1419 CA DEX
141a D0 F2 BNE $140E
141c 4C 22 FD JMP $FD22
nbla000 wrote: what's wrong in my routine?
1417 E6 F6 INC $F6
1417 E6 FE INC $FE
Also, you may want to locate this snippet of code to e.g. $1FE0, save it together with the relocated cartridge image and set that address as execution. It would mean after decrunching, the transfer routine would start immediately and then boot the cartridge image.
It is probably rather easy to hack Pucrunch (the source is out there) to accept VIC programs exceeding $8000, or at least binary patch the decruncher:
1. Transfer cartridge image from $A000 to $2000
2. Run PuCrunch, choose execution address $FD22 (reset)
3. Manually adjust decruncher to store data at $A000 instead of $2000
OPS... i've reread this code at least 10 times.....Code: Select all
1417 E6 FE INC $FE
It's relatively simple, you may modify one byte from $20 to $A0 in a specific memory location and save again the program (another step) or just a POKE before RUN.3. Manually adjust decruncher to store data at $A000 instead of $2000
Normally you preserve about 25% of space and 15/20% of time loading (From LOAD to the effective start).
In any case after experiments i think that the best way is to to modify Pucrunch to accept VIC programs exceeding $8000 for 2 reasons:
1) Because Pucrunch doesn't accept programs exceeding $8000 you need an additional step, to transfer cartridge image from $A000 to $2000 using the Vice monitor or other tools
2) When you load the crunched image you need 16K, 8k in bank 1 and 8k in bank 5 instead of 8k in bank 5 only because the crunched file is stored at bank 1 $2000 and decrunched in bank 5 $A000
Unfortunately i'm not a C programmer, someone want to make some adjustment to Pucrunch Source ?
I think you'll get the best result using the stand alone decruncher (sa_uncrunch.asm).
There is no overlap between the source and destination areas, so you don't need all the fancy copy to stack code and such.
Just crunch with the "-c0" option to get raw packed output, and then link it manually to sa_uncrunch.asm.
OK, now i've the crunched raw datatlr wrote:Just crunch with the "-c0" option to get raw packed output, and then link it manually to sa_uncrunch.asm.
pucrunch ImageA0.prg ImageCR.prg -c0 -x64802
But what means link it manually? I need to compile sa_uncrunch.asm and how?
Sorry i'm not so expert to understand what you mean, there is a compiled Vic-20 version of the standalone decruncher? If yes, how does it work?
Yes, you need to modify sa_uncrunch.asm slightly so that it has a sys-line, and then assemble it using dasm.nbla000 wrote:OK, now i've the crunched raw datatlr wrote:Just crunch with the "-c0" option to get raw packed output, and then link it manually to sa_uncrunch.asm.
It can quite easily be done in such a way that allows concatenating any packed cartridge data straight onto the assembled uncruncher.
If you do not know enough assembly, I'm sure someone here wants to help you out.
