VIC-20 with IEEE-488
Tonight, I tested an IEEE-488 interface with my VIC-20. It works nicely, allocating device 8 for the IEEE bus(*) and leaving i.e. device 9 for my 1541-II. I tried it by attaching a 5 MB 9060 hard disk, and managed to both bring up the directory and load files from it. Cool, but just temporary.
And some people have the misunderstanding that VIC-20 doesn't support disk drives at all.
(*) I don't know if daisy-chaining devices on the IEEE bus assigns different device numbers to each unit, and whether this interface would allocate a number to every IEEE unit prior to letting the IEC bus use them. When connecting a 1541-II as device 8, it worked as long as I didn't have any IEEE devices connected to the interface, so I needed to toggle the device number on the disk drive to use it simultaneously.
May I point you to http://www.baltissen.org/htm/cbmhd.htm ?carlsson wrote:Temporary = the hard disk is about to be sold, and I'm rather getting a IEEE-488 floppy drive (if I can find some suitable floppies).
Here you find a project that enables you to use a PC IEEE drive. A Pentium 1 will do. As my program only runs in real DOS mode, I advise to install W98 on it. This enables you to use its real DOS mode when simulating an IEEE drive and enables you to use the GUI mode for exchanging files over a network.
___
/ __|__
\ \__|_\
\___| URL: www.baltissen.org
Now I have a total of two IEEE-488 interfaces for VIC-20:
Dams Office Equipment: auto-starting, supposedly allocates device numbers depending on the number of IEEE devices on the bus. Other device numbers remain available to the IEC bus.
Handic IEEE-488: started with SYS 45056: ** HANDIC IEEE 488 **. It allocates (patches Kernel?) all device numbers from IEC bus, but it is disabled with RUN/STOP + RESTORE (and thus can the IEC devices be used again).
I'm unsure if this Handic interface is identical to Commodore's VIC-1112 interface. Does anyone own this cartridge and can tell whether it:
a) autostarts or requires a SYS
b) hogs all device numbers (like most IEEE interfaces for VIC/64 seems to do)
Actually it was one of many identical interfaces, but only one was pre-populated with 6522 chips, and for the moment I didn't need more interfaces. If anyone has use for them, I could probably pick up 2-3 more bare boards and sell, perhaps even populated with 6522 chips.
I've always wanted an IEEE interface for my VIC, in case I ever find a PET hard drive. But I wouldn't know where to get the missing chips, so if it was posible to get a populated one, that might be something I would be interested in.carlsson wrote:Actually it was one of many identical interfaces, but only one was pre-populated with 6522 chips, and for the moment I didn't need more interfaces. If anyone has use for them, I could probably pick up 2-3 more bare boards and sell, perhaps even populated with 6522 chips.
I have about 50 6522's laying around. I don't know what other chips are needed but the 75160 and 75161 are still available AFAIK.ral-clan wrote:But I wouldn't know where to get the missing chips,
___
/ __|__
\ \__|_\
