Emulator or Vic 20
Emulator or Vic 20
Just wanted to know.
Do you use the Emulator or the Vic-20 for computing.
I personally use.
A Real Vic 20 with 16k expansion.
1541 and a 1571 floppy
Mps 803 Printer
1702 Commodore Monitor.
And Last a Tape Drive.
I personally use.
Mps 803 Printer
I use both.
Mostly I use an emulator for a quick look at games to see what they're like, and definitely when developing.
But if I'm going to play a game seriously, I'd rather do it on the original machine. Mostly I use disks, but I'd like to put some games on tape (just for the hell of it.) I just haven't aquired a tape deck suitable for recording from my PC.
I have wired up an original Nintendo controller for use with the Vic and Atari.
Real VIC 20 with Nicolas Welte's RAM/ROM expansion
1541-II and 1541 drive
64HDD
Commodore 1084S monitor
64HDD
Bacon
Thank You
Thanks for the replys.
First off can this be done on a Vic with 16k expansion.
http://www.petscii.com/telbbs/listings.html
Of course a 16k or so bbs would have to be written.
Also will the rs232box and a null modem cable be compatible. I know they are doing it on C64's so can it be done with a Vic 20?
Last. It is so nice to see that others are using "The Real Thing"
Vic 20 is a great machine!
Got it to work!
[quote="Alan"]Wasn't Jim Brain working on something like this a while back?[/quote]
I got a box to work. Vic 20 works fine with telenet through pc.
