Last week, I programmed a BASIC text adventure game for the unexpanded Commodore VIC 20 called Tiny Quest. Now I've expanded my Tiny Quest game, it's now called Castle Quest, and it's basically a whole new game. (Requires 16K RAM expansion - also the original Tiny Quest is on the disk)
NEW - Updated version 1.1:
https://www.mediafire.com/file_premium/ ... K.d64/file
NEW - itch.io link
https://rickyderocher.itch.io/castle-qu ... vic-20-16k
NEW BASIC game for 16K VIC: Castle Quest
Last edited by ricky_derocher on Mon Feb 26, 2024 3:03 pm, edited 4 times in total.
Re: NEW BASIC game for 16K VIC: Castle Quest
Nice, just played it. At one place it says "duengon" where it should say "dungeon" probably...
At some point you get "silver coins". But "use silver" does not work. You have to "use coins".
At the very last step you have to "get" the item on screen instead of "use"ing it. Seems unintuitive.
After finishing the game it just hangs on the final screen. Ideally it should offer to restart or reset the VIC.
Thanks! I just updated the game to v1.1 based on your suggestions.
Opps. Silly spelling mistake. Fixed.At one place it says "duengon" where it should say "dungeon" probably...
The game will now accept both "silver" and "coins".At some point you get "silver coins". But "use silver" does not work. You have to "use coins".
It will now let you use it in addition to getting it.At the very last step you have to "get" the item on screen instead of "use"ing it. Seems unintuitive.
Now gives you the option to restart.After finishing the game it just hangs on the final screen. Ideally it should offer to restart or reset the VIC.
- Orangeman96
Ricky:
I really enjoyed this work of interactive fiction you created! It was fun, not too complicated, yet challenging nonetheless!
I especially liked the font you devised and the color scheme leveraged it most appropriately.
Keep up the great work; I look forward to your next adventure!
OGM
OGM
