Wayne / Art Ravers wrote: ↑Wed Sep 06, 2023 12:58 pm
WOW ! Thank You Orion70 ! That was a Fast reply - Respect due
Downloaded and will give them a go later !
Hi ! So I tried the 2 Games - Crazy Climber worked but APPLE BUG "threw a wobbly" - it tried to load the Gaame but crashed when it had finished Loading, Oh, I should add and I should have said - I am Loading off of an SD2IEC - So... Do I need a PRG Version or a D64 Version like the Commodore 64 does when handling the SD2IEC ? Sorry to be a nuisance. Other than that, Beeen upstairs earlier having some Vic Fun - Now there's something I bet you did'nt think you'd be reading today...
Yep it's a TAP file, you won't be able to load it with a standard SD2IEC equipment. Someone more skilled than me should convert it into a single PRG file, or two files on a D64.
orion70 wrote: ↑Fri Sep 08, 2023 2:13 am
Thanks Orion70 ! You tried, so Thank you for helping, To be fair, I have quite a few Vic 20 Games to be playing that I really enjoy. Also I am off on Holiday VERY shortly so I wont have time until I come back off my Holidays...
See you all soon !
Mayhem wrote: ↑Fri Sep 08, 2023 2:40 am
Yeah only a TAP file in GB20 mate, someone will need to convert it to PRG or D64 for you.
As Always Mayhem, You Sir... Are a Legend ! "Were not worthy, were not worthy" etc LOL
( Having said that - If I'd taken out a Copyright of my Name before "Wayne's World" I would be worth a Fortune right now - The Number of times people have quoted Wayne's World to me once they knew my name is UNBELIEVABLE ! )
Anyway, What's that smell ? - It's me - I'm Off !
BOOM BOOM !
wimoos wrote: ↑Fri Sep 08, 2023 5:56 am
applebug.zip
In this ZIP both files in PRG format. You need a VIC with no memory expansion.
APPLE1 needs to run first and then APPLE2
When run from disk you need to modify APPLE1 so that it loads and runs APPLE2 properly.
Regards,
Wim.
Excuse the delay, I am back - So I am back MOST EXCELLENT News - It works ! Oh boy oh boy, So pleased - Thank You wimoos.
Top Tip - If you are Loading it from SD2IEC like me - Load the First File first then Load"APPLE2",8 for the Second File.
