I just got my hands on one of these but it came without the fuse. Can anyone tell me what I need to replace it? I was hoping it would be in the manual but I don't see it.
Cardco Cardboard 3s fuse value
- mathom
...mathom...
Re: Cardco Cardboard 3s fuse value
Mine says on one side BUSSAGA/ on the other side 250V0LT. No other markings on it.
- mathom
Thank you for the clue. I have noticed in the manual that they list the approximate current draw of various cards. I suppose if I figure worst case and maybe add a bit of padding I can approximate the amperage? Any hardware folks out there have any insight on calculating fuse values?
...mathom...
