Printing (unsigned) 16-bit numbers in Assembly, how?
MrSterlingBS
Post by MrSterlingBS »
Hello,
some question about the integer to floatpoint and floatpoint to ascii routines.
When i have a result > 32768 i get a negative result.
How can i print out a value > 32768?
i use this routines from the VIC OS:
; mult22.a
; from Niels Möller: https://www.lysator.liu.se/~nisse/misc/6502-mul.html
; slightly tweaked for speed
; 8 bit x 8 bit unsigned multiply, 16 bit result
; Average cycles: 76.48
; 563 bytes
FLPASC 	equ $DDDD
INTFLP	equ $D391
CLRSCR	equ $E55F
WRTF	equ $E742
STROUT 	equ $CB1E
STACK	equ	$0100
multiplier	equ $26
multiplicand equ $28
min	    	equ $30
result_low	equ $32
temp3      	equ $34
producthigh equ $36
* = $1001
		; BASIC program to boot the machine language code
		db $0b, $10, $0a, $00, $9e, $34, $31, $30, $39, $00, $00, $00
	sei				; stop interrupts
	jsr CLRSCR		; clear screen
	lda #$00		; high
	ldy #230			; low
	sty multiplier
	jsr INTFLP		; integer to float point
	jsr Primm
	db "MULTIPLIER:  ",$00
	jsr FLPASC
	ldy #>STACK
	lda #<STACK
	jsr STROUT
	lda #$00		; high
	ldy #155		; low
	sty multiplicand
	jsr Primm
	db $0d,"MULTIPLICAND:",$00
	jsr FLPASC
	ldy #>STACK
	lda #<STACK
	jsr STROUT
; code from the book VIC-20 MACHINE LANGUAGE GUIDE Abacus Software
	lda #0
	sta $9129	; decrements every 256 µS	; 4 cycles
	sta $9128	; decrements every µS		; 4 cycles
	cld			; insure binary mode		; 2 cycles
	clc			; clear carry flag			; 2 cycles
; ************** Start Counter with 10 Cycles ********************
	lda multiplier
	ldx multiplicand
; In: Factors in A and X
; Out: High byte in A, low byte in result_low
mult:
    sta min
    cpx min
    bcc swap1
    txa
continue:
    sbc min
    tay
    ; at this point:
    ;   Y = max(inputs) - min(inputs);
    ;   X = max(inputs);
    lda sqtab_lsb,x
    sbc sqtab_lsb,y
    sta result_low
    lda sqtab_msb,x
    sbc sqtab_msb,y
    sta temp3
    clc
    ldx min
    lda result_low
    adc sqtab_lsb,x
    sta result_low
    lda temp3
    adc sqtab_msb,x
    ror
    ror result_low
    ;rts
	sta producthigh
	jmp endcalc
swap1:
    stx min
    tax
    sec
    bcs continue            ; ALWAYS branch
endcalc:
; ************** Stop Counter ********************
	lda $9128
	sta $FB
	lda producthigh
	ldy result_low
	jsr Primm
	db $0d,$0d,"SOLUTION:",$00
	jsr FLPASC
	ldy #>STACK
	lda #<STACK
	jsr STROUT
	lda #$FF
	sbc $FB
	sbc #10
	tay				; low
	lda #0
	jsr Primm
	db $0d,$0d,$0d,"CYCLES:",$00
	jsr FLPASC
	ldy #>STACK
	lda #<STACK
	jsr STROUT
	jmp *			; infinity jump
Primm:
	pla
	sta $03
	pla
	sta $04
X10D6:
	inc $03
	bne	X10DC
	inc $04
X10DC:
	ldy #$00
	lda ($03),y
	beq X10E7
	jsr WRTF
	bcc X10D6
X10E7:
	lda $04
	pha
	lda $03
	pha
	rts
; align tables to page boundary for best speed
sqtab_lsb: ;<x*x
    db 0,1,4,9,$10,$19,$24,$31,$40,$51,$64,$79,$90,$a9,$c4,$e1
    db 0,$21,$44,$69,$90,$b9,$e4,$11,$40,$71,$a4,$d9,$10,$49,$84,$c1
    db 0,$41,$84,$c9,$10,$59,$a4,$f1,$40,$91,$e4,$39,$90,$e9,$44,$a1
    db 0,$61,$c4,$29,$90,$f9,$64,$d1,$40,$b1,$24,$99,$10,$89,4,$81
    db 0,$81,4,$89,$10,$99,$24,$b1,$40,$d1,$64,$f9,$90,$29,$c4,$61
    db 0,$a1,$44,$e9,$90,$39,$e4,$91,$40,$f1,$a4,$59,$10,$c9,$84,$41
    db 0,$c1,$84,$49,$10,$d9,$a4,$71,$40,$11,$e4,$b9,$90,$69,$44,$21
    db 0,$e1,$c4,$a9,$90,$79,$64,$51,$40,$31,$24,$19,$10,9,4,$1
sqtab_msb: ;>x*x
    db 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
    db 1,1,1,1,1,1,1,2,2,2,2,2,3,3,3,3
    db 4,4,4,4,5,5,5,5,6,6,6,7,7,7,8,8
    db 9,9,9,$a,$a,$a,$b,$b,$c,$c,$d,$d,$e,$e,$f,$f
    db $10,$10,$11,$11,$12,$12,$13,$13,$14,$14,$15,$15,$16,$17,$17,$18
    db $19,$19,$1a,$1a,$1b,$1c,$1c,$1d,$1e,$1e,$1f,$20,$21,$21,$22,$23
    db $24,$24,$25,$26,$27,$27,$28,$29,$2a,$2b,$2b,$2c,$2d,$2e,$2f,$30
    db $31,$31,$32,$33,$34,$35,$36,$37,$38,$39,$3a,$3b,$3c,$3d,$3e,$3f
    db $40,$41,$42,$43,$44,$45,$46,$47,$48,$49,$4a,$4b,$4c,$4d,$4e,$4f
    db $51,$52,$53,$54,$55,$56,$57,$59,$5a,$5b,$5c,$5d,$5f,$60,$61,$62
    db $64,$65,$66,$67,$69,$6a,$6b,$6c,$6e,$6f,$70,$72,$73,$74,$76,$77
    db $79,$7a,$7b,$7d,$7e,$7f,$81,$82,$84,$85,$87,$88,$8a,$8b,$8d,$8e
    db $90,$91,$93,$94,$96,$97,$99,$9a,$9c,$9d,$9f,$a0,$a2,$a4,$a5,$a7
    db $a9,$aa,$ac,$ad,$af,$b1,$b2,$b4,$b6,$b7,$b9,$bb,$bd,$be,$c0,$c2
    db $c4,$c5,$c7,$c9,$cb,$cc,$ce,$d0,$d2,$d4,$d5,$d7,$d9,$db,$dd,$df
    db $e1,$e2,$e4,$e6,$e8,$ea,$ec,$ee,$f0,$f2,$f4,$f6,$f8,$fa,$fc,$fe
Thanks a lot for your help!
Sven
Reason: thread split from essentially unrelated topic, image link repaired
Re: Printing (unsigned) 16-bit numbers in Assembly, how?
Try the routine at $DDCD (PRTFIX), which takes X as low byte and Accumulator as high byte and prints a 16-bit positive integer:
        PRTFIX      = $ddcd             ; Print base-10 number
        jsr Primm
        db $0d, $0d, "SOLUTION:", $00
        ldx result_low
        lda product_high
        jsr PRTFIX
The normal BASIC integer type's range is -32768 ~ 32767
MrSterlingBS
Hi Chysn,
thanks a lot for your help.
The routine works fine now.
But...
I think you guess my question.
How can i printout 256 by 256 = 65536 or the range from 0 to 65535 ?
Is it possible?
Best regards
Sven
MrSterlingBS wrote:How can i printout 256 by 256 = 65536 or the range from 0 to 65536?
As long as you are working with an unsigned 8 bit x 8 bit -> 16 bit multiply, all numbers stay within the range 0..255 and 0..65535, respectively, so the need to print 256 or 65536 is not even a issue.
If you want to handle bigger factors and product results, you will need to extend both the multiply routine and the base conversion routine by yourself. In general, for a multiply of two n bit numbers, the result will always fit within 2n bits, so it is best you write a display routine for the 2n bit result, which will then also be capable of printing the n bit factors.
You might want to use those routines in 6502.org as blueprints: Large Multiply & Divide and "Hexadecimal to Decimal Conversion" (<- actually a misnomer: these routines convert a binary value to a BCD value).
Note using BCD mode on the VIC-20 requires you to either execute the involved routines with interrupts off, or provide a small IRQ wedge with CLD as first instruction, as the NMOS 6502 does not clear the D flag upon interrupt entry, neither does the KERNAL IRQ handler.
Adaption of those routines to the VIC-20, including a BCD to ASCII conversion left as exercise for the reader.
MrSterlingBS
Hi,
excuse my poorly asked question.
The multiplication of 255 by 255 is 65025.
But the range is from 0…65535 ?
How can i calculate and print values above 65025?
or am I confusing something?
The german book „VC–20 intern“ describes the routine $DDCD with a range from 0…65535.
Best regards
Sven
PS: I come to the questions to understand the famous work of Tobi Lobster that he published on github.
https://github.com/TobyLobster/multiply_test
MrSterlingBS wrote:How can i calculate and print values above 65025?
As I wrote in my preceding post:
"If you want to handle bigger factors and product results, you will need to extend both the multiply routine and the base conversion routine by yourself. In general, for a multiply of two n bit numbers, the result will always fit within 2n bits, so it is best you write a display routine for the 2n bit result, which will then also be capable of printing the n bit factors."
Emphasis added.
MrSterlingBS wrote: Fri May 12, 2023 2:20 pm How can i calculate and print values above 65025?
If you want to make a "biggerint" type, I can point you here, which is a post I did a few years ago about Decimal Mode, how it works, some of its pitfalls:
http://sleepingelephant.com/ipw-web/bul ... php?t=9651
I'd respectfully disagree with Mike (which is admittedly an epistemologically-risky thing to do in general) about needing to worry about the IRQ when using Decimal Mode in your regular code. There are no ADCs and only a few SBCs in the whole service routine path, and their function is radix-agnostic. But it's a good idea to be careful with Decimal Mode because the VIC-20 never clears the flag; if it's left on, things get weird. So just clear it when your code ends, or before you do other ROM calls. Have a reset button.
But it promises to make base-10 printing routines pretty easy to write, regardless of what size you need.
tlr
Post by tlr »
There's also some discussion this thread: http://sleepingelephant.com/ipw-web/bul ... p?p=114085
