Custom ROM Kernal
- mythic66
- Occupation: Technician
Custom ROM Kernal
Hi,
I'm struggling to make my program boot, here's the detail. I wrote a simple program, bare metal, using no Kernal routines, to print a string at the screen. ORG is at $1001 for testing purpose. Works perfectly in VICE for Unexp VIC.
I then change the ORG for $E000, make a 8192 byte bin file, set FFFC and FFFD to $E000 in the file
I then tried to replace the kernal file in vice by mine, no joy for the execution. I also tried to burn an eprom to try on a real VIC20, still no boot.
The program init the vic chip, then print directly to the VRAM a short string. No interrupt is use, no fancy here.
Any hint ?
Any hint ?
Re: Custom ROM Kernal
Did you duplicate the VIC setup code? There's a table of register values that are used to initialize the VIC registers, without that it won't display the expected 22*23 screen positioned correctly, and most importantly, be looking at $1E00 for your data.
- mythic66
yes, as stated, I init the VIC chip, each of its register are configured properly.
I suspect something with the reset vector and/or other vectors, but they are imo, configured correctly.
VICREG byte $04 ;$9000 - horizontal centering
byte $19 ;$9001 - vertical centering
byte $96 ;$9002 - set # of columns /
;Bit7 = screen base bit ($16 for screen at $1000)
byte $AE ;$9003 - set # of rows
byte $7A ;$9004 - TV raster beam line
byte $F0 ;$9005 - bits 0-3 start of character memory /
byte $00 ;$9006 - horizontal position of light pen
byte $01 ;$9007 - vertical position of light pen
byte $FF ;$9008 - Digitized value of paddle X
byte $FF ;$9009 - Digitized value of paddle Y
byte $00 ;$900A - Frequency for oscillator 1 (low)
byte $00 ;$900B - Frequency for oscillator 2 (medium)
byte $00 ;$900C - Frequency for oscillator 3 (high)
byte $00 ;$900D - Frequency of noise source
byte $00 ;$900E - bit 0-3 sets volume of all sound /
;bits 4-7 are auxiliary color information
byte %00001000 ;$900F - Screen and border color register
mythic66,
please do the people reading this thread and trying to help a favour and post the source, or at least the KERNAL binary file you built. Without any of them, any speculations about the reasons why the code fails are only that: speculations.
Besides, code that is just supposed to print a message on screen, bare-bones, without any KERNAL assistance still can't be that involved so you could have a reasonable interest not to disclose it.
- mythic66
Mike,
There's nothing secret there !, just a quick program for testing purpose. It's not been optimized at all
defm PrnScr
lda #/3
sta VPTR ; Init video ram pointer
sta CPTR
lda #/2
sta VPTR+1
clc
adc #$78 ; Init color ram pointer
sta CPTR+1
lda #0
sta LROW;
ldy #0
ldx #0
@loopR0 lda /1,x ; Load buffer
beq @exit ; buffer end 0?
cmp #$A0 ; Line feed?
bne @loopR1 ; no
lda LROW ; LineFeed subroutine
clc
adc #$16
bcs @xloop0 ; Over $FF
sta LROW
tay
inx
jmp @loopR0;
@xloop0 sta LROW ; second part of the screen
tay
@xloop1 lda #$1F
sta VPTR+1
lda #$97
sta CPTR+1
inx
jmp @loopR0 ;----------------------
@loopR1 sta (VPTR),y ; Print Char
lda #/4
sta (CPTR),y ; Color Char
iny
beq @xloop1
inx
jmp @loopR0;
@exit nop
endm
; Basic STUB
*=$E000
; byte $0C, $10, $DC, $07, $9E, $20, $34, $31, $31, $30, $00, $00, $00
; Main routine
Main
jsr VicInit
jsr ROMenu
Exit rts
; ROM
ROMenu
jsr ClrScr
PrnScr TOPBOX1,$1E,$CA,#6 ; Box
PrnScr SCRA0,$1E,$E3,#4 ; Title
ROMexit rts
; Clear screen routine
ClrScr
ldx #0
loopC0 lda #$20
sta $1E00,x
lda $01
sta $9600,x
inx
bne loopC0
loopC1 lda #$20
sta $1E00+255,x
lda $01
sta $9600+255,x
inx
cpx #$FB
bne loopC1
rts
; VIC chip initialisation
VicInit
ldx #0
loopV0 lda VICREG,x
sta $9000,x
inx
cpx #16
bne loopV0
rts
; Const and variables
LROW byte $00 ; last row
VPTR =$FB ; ZP Video pointer
CPTR =$FD ; ZP Color pointer
; Menu Box
TOPBOX1 byte $55,$43,$43,$43,$43,$43,$43,$43,$43,$43,$43,$43,$43,$49,$A0
byte $42,$20,$20,$20,$20,$20,$20,$20,$20,$20,$20,$20,$20,$48,$A0
byte $4A,$46,$46,$46,$46,$46,$46,$46,$46,$46,$46,$46,$46,$4B,0
SCRA0 text 'test rom',$A0,$A0,0
*=$FFFC
byte <Main, >Main
The two LDA $01 (ZP address mode) in the loops loopC0 and loopC1 are in error and quite likely should instead be LDA #$01 (immediate address mode) to load white (=1) as value for the colour RAM.
"/1", etc. look somewhat non-standard syntax for me. What are they supposed to do?
Finally, it should go without saying that you can't hold mutable values (i.e. variables) in ROM. STA LROW won't succeed.
- mythic66
Thanks for the reply, I'll correct the errors.Mike wrote: ↑Sun Feb 26, 2023 7:46 am The two LDA $01 (ZP address mode) in the loops loopC0 and loopC1 are in error and quite likely should instead be LDA #$01 (immediate address mode) to load white (=1) as value for the color RAM.
the " /1 " is the argument given to the macro when I call it.
Hmm, totally agree about the variables, nooby error..
- mythic66
After some head scratching, I found the problem. I had to put NOLOADADDRESS at the beginning so the compiler don't add the ORG address at the beginning of the bin file.
Works great !
Works great !
- MrSterlingBS
Hello,
Is there a guide here in the forum for creating a ROM?
I would integrate this into VICE.
Sven
Sven
Replacing the KERNAL ROM used by vice is as simple as running it withMrSterlingBS wrote: ↑Wed Jun 28, 2023 2:46 am Is there a guide here in the forum for creating a ROM?
xvic -kernel my-rom.bin
As srowe already wrote, providing a binary image without load address with a (file) size of exactly 8192 bytes most probably is the least of problems. For that matter, the VICE UI also provides a dialog box to specify the files to be used as BASIC, KERNAL or Character ROM (the latter is only 4096 bytes in length).MrSterlingBS wrote:I would integrate this into VICE.
It is rather easy to customize the existing KERNAL for own screen colours and start-up message. Anything beyond that (up to designing an own OS from scratch) is likely beyond what could be conveyed in a guide or tutorial. As a starter, you might want to answer yourself the question why I used the following instruction sequence in my fix of the multiplication routine:Is there a guide here in the forum for creating a ROM?
.DF6A A0 01 LDY #$01
.DF6C 98 TYA
.DF6D 4A LSR A
.DF6E 85 26 STA $26
See also this post and this other post, and to quote from the latter:
Mike wrote:[...] all [machine code and] table data could be somehow be referenced by some 3rd party program. There is no abstraction layer whatsoever (the KERNAL jump table being a honorable exception) which would help here [...] if you begin to change the ROMs, you just enter a continuum where more and more programs fail, in proportion to the amount of changed code. [...]
