On a VIC-20 keyboard, what would be the barrier to the space bar working reliably?
It works if I hit it in just the right place (about 3cm [~1 inch] from the left edge), or in other places if I really whack it hard. In other places, it does nothing.
All the other keys actuate as normal. I have not yet disassembled anything.
Space Bar Blues
Space Bar Blues
Re: Space Bar Blues
You don't mention what type of keyboard you have. The conductive pads on the PET style ones can become contaminated with oil, degreasing using ammonia restores them. You might also have dirt on the gold contacts, a wipe with a IPA cleans that off.
Re: Space Bar Blues
It's a C64-type keyboard with grey function keys. Non-PET, non-Eurostyle, boring-ass concave keys. I'll try the alcohol on the contacts, thanks!
I've got an incomplete keyboard that I might disassemble as a practice run if that doesn't work.
Re: Space Bar Blues
Oh, thanks! Jeff's helped me many times, mostly with Sharp pocket computer stuff.srowe wrote: ↑Fri Jan 20, 2023 12:12 pm This might be of use
https://www.youtube.com/watch?v=n9gGz2n-sBU
