Video noise on VIC-20
JonBrawn
Re: Video noise on VIC-20
Post by JonBrawn »
JonBrawn wrote: Mon Mar 20, 2023 3:07 pm worked for me without interference
I lied. Well, sort of. I haven't had interference on the two LCD TVs I've been using as monitors, but I recently hooked up to a CRT TV, and there was a horizontal band of interference rolling slowly down the screen.
I can feel a chonky big transformer and a couple of power transistors in my future.
https://youtube.com/@vicenary
USA_Joe
Occupation: Retired
Post by USA_Joe »
I had a similar issue with my VIC-20 and C-64. I ordered a new cable with stronger insulation, and the issue went away. The cable for the video (yellow connector) is very thick on the new one.
Joe
JonBrawn
Post by JonBrawn »
Probably better shielding rather than insulation, and that may well improve the signal quality. Sounds like an easy fix!
USA_Joe
Occupation: Retired
Post by USA_Joe »
That's the word I was looking for at the time! Shielding!
Joe
Is there a cheap and effective way to shield video cables?
JonBrawn
Post by JonBrawn »
Well, I'd truly advise buying a better cable, but determining what is a better cable and what is just a rubbish expensive cable is a skill that I don't possess - other than to say gold plating is not evidence of quality.
USA_Joe
Occupation: Retired
Post by USA_Joe »
Here's where I purchased mine for my VIC 20's and C64's that I have. I could tell the difference immediately from my regular composite cables I was using.
https://www.ebay.com/itm/165784501517?h ... Swa5RgAQOO
Joe
