Ok, this might be really simple, but I can't figure out what to do.
I've been messing around with SIDPLay for windows, and would
like to try some of the .sid files with the real thing.
What program will do that? Do I need to first convert the .SID
files somehow to .D64? I looked at Computes Sidplayer, but
it appears to use a different format (.MUS) ?
Thanks!
Brian
How can I play .SID files on C64?
- Schema
- factor
SIDPlayer for the IDE64 should work on a stock system, too. SYS4096 to start it, I believe.
ftp://c64.rulez.org/pub/c64/IDE64/Tools ... er_v3c.zip
